DRL Error when leds are installed
Old Jun 20, 2016 | 01:37 PM
z643167z's Avatar
is there a way to disable the DRL ERROR on my dash... i have conntected everything properly so i am looking for a fix to disable this error
Old Jun 21, 2016 | 11:30 AM
RTM's Avatar
RTM
I would imagine the DRL error is from not having high enough resistance in your LEDs. There is a post over on TSXclub about it working, but I don;t see how much resistor load he had to add, guessing 8ohm per side based on the label on the box.
white led DRL with NO error message! - Acura TSX Forum
This post says a 6ohm load will be sufficient to kill the message
Turn off daytime running lights - Acura TSX Forum
mazen222
May 10, 2026 01:41 PM
sERKZ
1/2G MDX (2001-2013)
May 29, 2016 10:45 AM
