Driver side window shutting with a bang
Just wondering if anyone else has this problem.
Its starting to get nice in the Chicago area and I had my front windows open about 1/4 down. When I closed the driver side window, it closes with a loud bang when it gets to the top. The passenger side seems normal as all the other windows. After inspecting the area a bit, it seems like the window seal is off a little bit so as the window comes up, it catches it a little bit. When more pressure is applied, the seal falls into the normal position and the glass falls into the groove with a bang.
Meh, this is a common issue with a lot of cars. The weather stripping adhesive starts to fall apart, your car probably sat on the lot for a while before you picked it up. Take it in for warranty work they will replace the seal, and the adhesive. Should have them check all 3 of your other windows as well. Other wise you'll start putting the window down when it gets hot outside, and half your seal will be hanging from the window..
rockyboy
08-04-2024 10:35 AM
marcelft
07-10-2018 06:17 PM
sockr1
10-01-2015 01:31 AM
