Door Actuator and Memory seats
Old Feb 6, 2015 | 02:58 PM
ballerholic's Avatar
My left rear passenger (behind driver seat) door isn't locking/unlocking through the keyfob or the unlock/lock inside the car.
Not sure if it's related but I also noticed that there is no longer any power to my memory seat options. I remember that they used to be green if in seat 1/2 position and the set button doesn't work anymore.
With the door not being able to unlock, would that be a reason that the fuel door can't open or is that more related to the service bulletin about replacing the fuel fill door push lifter?
Thanks for any insight!
Old Feb 6, 2015 | 08:31 PM
ulrblitzer's Avatar
If I remember the owners manual correctly, the fuel filler door is accessible when the car is unlocked. That actuator stuck on lock might be the reason why you can't open it.
My driver side rear is making noise when I lock/unlock too. Probably won't be too long before it goes out like yours.
Old Feb 9, 2015 | 04:25 PM
Makes sense, too bad I'm outside the warranty.
I guess I can manually unlock the door for the time being and the gas door until I fix it myself or get robbed at the dealership
Old Feb 11, 2015 | 06:47 AM
MrTee12's Avatar
Have the car checked out to see what part you need. Then order off of Ebay.
This happened to me aswell. But with my driver's side window. The dealership wanted to replaced the button for $349.
I ordered a used door panel switch with buttons for $75 and had it installed somewhere else for $50.
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
