2014 tsx
Old May 20, 2015 | 05:04 PM
3.2cls6speedmt's Avatar
2014 tsx
helping a family member purchase a cpo 2014 tsx with about 15000 miles. The technician's cpo report states front brakes are at 8 mm and rear brake pads are at 7 mm. The front rotors are at 27.8 and rear rotors are at 10.9 mm. Are the rear brakes below 50 percent? Shall we ask for new rear brakes and rotors?
Old May 20, 2015 | 07:29 PM
magnumpi's Avatar
9th Gear
I don't recall ever seeing back calipers/rotors as big as fronts. Weight transfer would put far more braking onto the front wheels. I have seen in my research however, that it seems the rear pads wear more quickly than do the fronts. It defies logic, but I'm sure there's a valid reason. Maybe check the technical specs for some of these measurements. Craig
Old May 21, 2015 | 07:31 PM
wpgacurafan's Avatar
Factory rear discs are spec at 9mm thickness, They are solid rotors, not ventilated, which is why they are not as thick. The tech has actually measured the rears at thicker than stock. Perhaps previous owner had installed an aftermarket brake upgrade.
tsx_boy
Dec 13, 2019 08:33 PM
mlody
Dec 4, 2019 02:11 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
ceb
ILX
Sep 27, 2015 10:56 AM
