2009 Acura spray nozzles not working with hood closed
Hi All
I have a weird issue with my 2009 Acura TSX The spray nozzles work fine with hood open, but will not spray with hood closed. Thanks |
they're being pinched somewhere. Follow the hoses.
Stupid question. Where are the hoses for the washer reservoir? I've only had the car a few days and looked under the hood and can't see them.
Have you checked the underside of the hood? :scratch: The fire blanket /insulator may be covering it. Follow the nozzles :tomato:
The nozzles are mounted to the black cover at the bottom of the windshield. The hose has to be under that. I think where the hinge folds under the the black cover is where the hose is getting pinched.
(Post 15968827)
Unfortunately, I have no idea about this problem aside from what's been said about, "follow the path from the nozzles back to the reservoir." |
:doh: stupid me.. :sorry:!
I was basing my observation on this diagram here:OEM Acura TSX SEDAN 2009 WINDSHIELD WASHER (KA) partshttps://cimg8.ibsrv.net/gimg/acurazi...732ba27a2e.gif Somehow, when the hood is closed, either the plastic cowl is is pinching the hose or the hood itself My guess is the issue is going to be in the top left corner of the hood area when facing it. |
Hi all,
Does anyone know what the part number for the windshield nozzle sprayer? |
Originally Posted by msharifi
(Post 15995222)
Hi all,
Does anyone know what the part number for the windshield nozzle sprayer? #15 https://www.oemacuraparts.com/auto-parts/2009/acura/tsx-sedan/tsx-trim/5-speed-automatic-engine/body-air-conditioning-cat/engine-hood-scat/?part_number=76810tl0003 |
(Post 15995239)
76810-TL0-003
#15 https://www.oemacuraparts.com/auto-parts/2009/acura/tsx-sedan/tsx-trim/5-speed-automatic-engine/body-air-conditioning-cat/engine-hood-scat/?part_number=76810tl0003 Thank you would this work for 2011? assuming 2009-2014 same part? |
(Post 15995240)
Did you click on the link? There's a blurb that says, "This part also fits" :tomato: |
yes thank you so much :)
