2009 Acura spray nozzles not working with hood closed
Hi All
I have a weird issue with my 2009 Acura TSX
The spray nozzles work fine with hood open, but will not spray with hood closed.
they're being pinched somewhere. Follow the hoses.
Have you checked the underside of the hood? The fire blanket /insulator may be covering it. Follow the nozzles
The nozzles are mounted to the black cover at the bottom of the windshield. The hose has to be under that. I think where the hinge folds under the the black cover is where the hose is getting pinched.
Received 7,772 Likes
Unfortunately, I have no idea about this problem aside from what's been said about, "follow the path from the nozzles back to the reservoir."
stupid me.. !
I was basing my observation on this diagram here:OEM Acura TSX SEDAN 2009 WINDSHIELD WASHER (KA) parts
Somehow, when the hood is closed, either the plastic cowl is is pinching the hose or the hood itself
My guess is the issue is going to be in the top left corner of the hood area when facing it.
Thank you would this work for 2011? assuming 2009-2014 same part?
