spark plugs
Old Feb 21, 2018 | 06:47 PM
smokin joe's Avatar
5th Gear
i just bought my 2011 acura tsx 2.4 with 129000 miles and i want to do some maintenance that seems to be overdue.which spark plugs should i use? also, is there an external a/t filter to change? my 2000 tl did have one. Should i do a transmission fluid change? should i do a 3x3? i did the air filters,is there anything else that im missing? fuel filter perhaps?
thanx for your input
Old Feb 23, 2018 | 06:39 AM
TSXV6Guy's Avatar
Get the factory spark plugs. I don't think there is an external A/T filter. If the transmission oil has not been changed in a while, don't do a 3x3. Just drain and refill, drive a few months, then another drain and refill.
Fuel filter is inside the gas tank, so changing it may be complex / dangerous depending on your skill level / experience. Check the Air conditioning filter, behind the glove box, and clean the mass airflow sensor (small sensor located right after the air filter, on the intake tube. Held by 2 screws. Use a spray sensor cleaner)
Old Feb 23, 2018 | 09:47 AM
smokin joe's Avatar
5th Gear
Which are would you suggest? I've heard all sorts of debates and opinions...redline amsoil etc
Old Feb 23, 2018 | 09:48 AM
smokin joe's Avatar
5th Gear
atf I meant
Old Feb 23, 2018 | 10:08 AM
Oem atf dw 1
Old Feb 25, 2018 | 12:19 PM
Tsx780's Avatar
Pcv valve. Fuel injector cleaner, use ngk irriduim spark plugs
Old Feb 25, 2018 | 12:37 PM
smokin joe's Avatar
5th Gear
Should I replace the pcv valve?
Old Feb 25, 2018 | 12:38 PM
smokin joe's Avatar
5th Gear
Those are the spark plugs I used thanks for all the advice
eastcoastguy
Jun 10, 2023 03:52 PM
e1828
Oct 18, 2002 08:28 PM
dcsquirm88
Jul 12, 2002 01:52 AM
Nex
Feb 20, 2002 08:15 PM
