Looking for PCD/HFPC I4 tester around Chicagoland
tsxronald (09-12-2011)
#83
Sweeeeeeetttt, this is going to be nice
#86
These have been tested to work without throwing a CEL?
I would like to pick up the high flow cat version of this when available. I already have the p2r secondary pipe, and will need a cat in the path.
#87
The PCD is in final testing to ensure no CEL's, so far so good. The P2R pipe will not be compatible with the RV6 PCD. Development of the high flow cat option is on hold right now since they moved to a new bigger location and are currently setting up the shop again. Development of the HF CAT should go quick since it's a simple part.
#88
#91
Hate to sound dumb, but can someone elaborate for me since he cant...
#92
I dont understand NOTHING!!!
What Cel ?
Need Pics or i Die as a Idiot.
I´m trying to build my own Downpipe in Germany, might be interesting for me, what you guys talk about.LOL
What Cel ?
#93
Its either one or the other. If you have the RV6 PCD installed, you cannot have the p2r pipe installed. If you have the p2r pipe installed, you cannot have the RV6 PCD installed. You cannot have both pipes installed at the same time. Did I clear everything up?
CEL = Check Engine Light
#94
Cel = check engine light... noob!
Let us know how it goes building the down pipe in Germany.
#95
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
#96
For the RV6 PCD, there will be options to keep the secondary CAT, replace it with the High Flow CAT, or have just a straight pipe. Not sure what options will be available when the PCD is released since it all depends on getting the shop set back up after their move.
#97
Thats kinda dumb...so we cant have both or else we will have CEL wtf...
#98
Well, I need to get my stock pipe back from that other vendor then, as I want to free up the flow closer to the head, which I think is a bigger choke point.
If all works out ok, I'll have a p2r pipe for sell I suppose. ??
#99
It is not about getting a CEL. There is no way to bolt up both at the same time. Sorry I cant post a pic of it, the pic would show it clearly. I guess you could say that the RV6 PCD will functionally take the place of the p2r pipe.
Testing is taking awhile since the Primary 02 sensor is mounted to the top of the precat and the secondary 02 sensor is mounted right after the precat to measure the exhaust gas. RV6 is fine tuning the PCD geometry in order to prevent the car from throwning CEL's. The secondary CAT that the p2r got rid of is there only to obtain the ULEV rating.
#100
So this is better the the P2R pipe....wow...waste of 200 bucks hahaha RIGHT ON!
#101
Just a small PCD teaser:
http://www.youtube.com/watch?v=c_JxrTy_Y5g
Taken with my phone so sound quality is so-so. Quality is a bit better when going to 720p. It sounds super loud in the vid, but I think its cuz of the garage.
ed_423 (09-14-2011)
mantra1 (09-14-2011)
#106
#107
You will have the option of replacing the secondary CAT with either a High Flow CAT or Test Pipe (test pipe will give you a full catless exhaust
I think RV6 wants to do it this way to give customers options on how they want to customize their exhaust or to make swapping CAT, High Flow CAT, Test Pipe easily for track days or emissions.
The following 2 users liked this post by thunderbt3:
live2hit01 (09-14-2011),
tsxronald (09-14-2011)
#108
So can i get the high flow cat from them or something else with my P2R pipe or am i stuck?
#110
At launch, the only option that will be available is the delete the primary CAT aka pre-cat (PCD - Pre Cat Delete). You will still need the secondary CAT to fit everything up.
). The options development has been put on hold due to the RV6 shop move/upgrade, but they'll probably be able to design those parts quick since they're fairly simple.
#111
Former Sponsor
The donut has been removed, basically it goes head > flex pipe > secondary cat. I don't want to release the design yet unit production is further along. I am shooting for around black friday.
#112
#113
#116
to the first person to dyno this: please do a before and after dyno, not just an after
#117
#118
Former Sponsor
*cough* Tannis *cough*
