honest opinion on throwdowns downpipe w/ cat delete...
does this make a noticeable gain? i want one but i cant justify the price. i can care less about the sound, id rather have just a bit more power. exhaust and ecu mods are the only ones i want.
You do know that doing a cat delete is illegal in every first world country - and in the US.
This is the second cat, the primary cat is quite large.
I have had mine on for some time, no exhaust scent that comes from running catless on other automobiles. The motor does respond better, I will be replacing mine with the high flow cat from Rv6 when it becomes available, so mine will be going up for sale then.
I will most definitely let you know first.
im baaaack!!
We've heard good response since bringing this to market. Definitely good for a hp bump. As mentioned above, this does not delete your primary cats (coming right off your motor) which would throw a code and smell like gas, but is a pipe running after your primary cats and deletes your (second) catalytic converter right before your catback exhaust.
https://acurazine.com/forums/4g-tl-performance-parts-modifications-295/feeler-rv6-09-tl-precat-deletes-high-flow-precats-803814/
08_UA7_Gr33k
02-11-2016 02:17 PM
DerrickW
11-15-2015 05:52 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
