h pipe? j pipe? down pipe?
Old Sep 8, 2011 | 11:26 PM
f1sh's Avatar
anyone wanna explain to me what a H pipe or J pipe or Down pipe is ?
or a Catback
Old Sep 9, 2011 | 08:49 AM
HeavyDuty's Avatar
WTH happened to my garage
H Pipe most commonly used to describe a rwd V6 or V8, V10, V12 where both pipes after the manifolds are run parallel down the length of the car, and a balance tube is made between them to "balance" the pulses each and to the other.
J-Pipe most commonly referred to a FWD V6 and connects the two primary exhaust manifolds and turns into one larger pipe that, in these cars cases then routes to a single pre-cat or single catalytic converter, then out the back from a cat-back.
Downpipe is usually (IMHO) referred to as the exhaust piping that comes out of the turbine housing on a turbocharged car. It's for spent gases that have already done their job turning the turbine, and they are on their way to a cat or cat back.
I don't know what people are referring to on these 4 cylinder, 45 degree angle pre-cat...outlets that incorporate a pre-cat.
Hope that helps.
Old Sep 9, 2011 | 10:20 AM
saucy's Avatar
Hope that helps.
Well put.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
johnpancakes014
Sep 27, 2015 12:58 PM
Rcelestino93
Sep 23, 2015 10:01 PM
