Flywheel + Clutch upgrade
has anyone done this on the CU2 yet? i am looking for an upgrade since our car is going to produce a lot more power in the future..
He used the rsx clutch/flywheel combo... the aftermarket made his car misfire or something?? I'm not sure, Talking to acura techs they think it may have been mis installed. However, he used the dc5 type r flywheel, which is like 10.5 lbs or something, with the same exedy or whatever manufacturer clutch and it worked fine.
I want to swap this out also... but am trying to line up a time frame to swap out the differential in my car first. If I can do it all at one time I may do it... Think I should do the lsd install first and made sure the car takes to it with no problems with like traction control or what have you.
fn 2 awsum (09-19-2012)
the 1g tsx doesn't share the same transmission as the 2g, does it? Regardless, I'd search for tranny parts from the 9th gen si, guaranteed to fit from what I hear.
SidhuSaaB
05-30-2020 12:40 AM
