Flashpro for 09-10 TSX released!
w00T! CT Superchargers are going to be very close behind now!
http://www.heeltoeauto.com/product.php?productid=66032
What is the price on the supercharger going to be?? Any lower since the engine management is separate?
Hope this isn't a dumb Q. but do you think if I swapped my 2012 ECU with a 2009 ECU, I could use flashpro now without complications? Or is it possible our cars will reject the foreign ECU.
Anybody have it tuned yet? this is the next mod on my list...i just wanted to see gains
I've been bumped 4 times for tuning. I now have an appointment for Monday at 11am. We will see what happens. BTW it's 100+ degrees here for the past 3 weeks, so expect low power...
How would I go about getting this flashed in the Seattle area - do people go somewhere to get it flashed? Or do they just buy the Hondata unit and do it themselves?
Does anyone have dyno results?
Thanks!
Thanks!
I would contact Hondata. I'm pretty sure they put that custom tune on your ECU for the CT-E SC. It's just the Flashpro security checking and trying to prevent people that don't own the TSX or have the 09-10 ECU from using it.
I know how to fix it.
go to http://www.hondata.com/downloads.html
Get this version: V1.3.3
It'll fix it!
It'll fix it!
ROTAREDOM
I can't wait to buy mine, this is gunna be fun!!
What version of code are you running right now? the 1.3.3 I "believe" I'll check later to make sure is the version I'm running.
When you ran through the install, did you tell the software you wanted to run the 09 tsx as the car?
If you aren't running the traction control I'm not what you gain running 7 v 3 of the code. Reach out to hondata on their forum. I had the same problem, and was told to download the code that supported the 09 tsx. Problem was fixed.
Beta doesn't equate elite. It just means it's code that is past alpha phase, but not necessarily ready to show time for all customers. Beta is code for lab work to be completed on. I would never run beta software on a customer's equipment.
Oh, yours is the car with the original hondata reflash for the CT supercharger huh? Maybe that's why the code/OS version doesn't like it.
What if acura flashed yours back to stock?
Registered Schmegistered
I'm not doing that without a way to back up the current ecu tune. Hondata put a lot of time into my current tune and the car is running great. I don't want to screw it up by goi g backwards.
My catless pipe is not here yet anyway. The only thing ill need the flash pro for is tu I g once I get it installed and dyno'd. I'll need to disable the secondary cat sensor and add some fuel and timing I think.
Just throwing it out there.
The v6 uses a different ECU, so I would be willing to say that it will not work.
There is an option for the V6 crowd though, it's already out in the wild in TL land. It's a piggy back set up. If you go searching for it, you'll find it.
GWEEDOspeedo
01-15-2016 10:39 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
09, 10, 2009, 2011, acura, cheap, difference, flash, flashpro, forum, hondata, information, pro, supercharging, tsx
