Ct-e icebox lid rubbing on hood....
Old 07-08-2015, 03:03 PM
  #41
Graphite Ghost
robpp's Avatar
lets talk FACTS WITH REAL WORLD EXPERIENCE.....enough of the internet pontificators
i own a 2nd gen tsx.
i owned a CTE Icebox for said vehicle.
My lid did not touch the hood insulation.
also, there have been many of those discussed on this forum and others and I have not seen any other reports about this.
The assumption is you installed it correctly. IIRC you couldnt mess up the box install.
But what about the lower pipe that slips onto the bottom of the box. maybe you are adding enough LIFT from down there to cause the interference with the hood.
Also, I know others have talked about the lids having a weird shape and causing some issues. On mine I used some 1/2 foam tape around the top of the box then bought some allens and rubber washers to hold the lid on. Did you add foam under the lid that might be causing this?
Good Luck!
rockstar143 (07-08-2015)
Old 07-08-2015, 04:11 PM
  #42
rockstar143's Avatar
Received 19,926 Likes on 14,464 Posts
I think his thread was a call for help that you just answered...
Old 07-08-2015, 04:32 PM
  #43
Graphite Ghost
robpp's Avatar
opposite the results of your presence Im sure.
Ill just leave this here:
pon·tif·i·cate
verb
pänˈtifiˌkāt/
1.
(in the Roman Catholic Church) officiate as bishop, especially at Mass.
2.
express one's opinions in a way considered annoyingly pompous and dogmatic.
"he was pontificating about art and history"
synonyms: hold forth, expound, declaim, preach, lay down the law, sound off, dogmatize, sermonize, moralize, lecture; More
Old 07-09-2015, 06:59 AM
  #44
For a guy that wants to give an appearance of intellectual superiority, your grammar and punctuation leave much to be desired. In addition, you became the definition of your last post WITH your last post. Bravo.
And for the record, I wasn't being sarcastic. Your post actually was helpful, although you really didn't say anything new or earth shattering. I'm sure OP will deeply value your insight though since you have the same car and intake.
The only reason I felt compelled to bother with this thread is I'm intolerant of any member telling anyone where they are or are not welcome to post.
Old 07-09-2015, 07:03 AM
  #45
Received 16,260 Likes on 11,971 Posts
Thanks Robpp for not ribbin' on me
Did OP install it correctly?
Old 07-09-2015, 07:06 AM
  #46
Old 07-09-2015, 07:10 AM
  #47
"noobies, come out to plaayaaaeeee"
Old 07-09-2015, 07:15 AM
  #48
I'd rather boobies...
Old 07-09-2015, 07:28 AM
  #49
but will they rub?
rockstar143 (07-09-2015)
  #50
OMG I FKNG HOPE SO!
justnspace (07-09-2015)
Old 07-09-2015, 11:07 AM
  #51
SgtSir440's Avatar
Butt, if they are rubbing in a bad way like the OP, you can probably fix the issue by cutting out a piece of the insulation or apply personal lubricant generously
Old 07-09-2015, 11:36 AM
  #52
Now you're getting it! All the problems will be solved with a dab of astroglide!
Old 07-25-2015, 07:30 AM
  #53
Leester01's Avatar
Tough crowd ��
OP if you decide to get rid of the intake Pm me.
Old 07-25-2015, 08:01 AM
  #54
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Fair warning: I read somewhere that it might rub.
08KBP_VA
10-22-2019 01:55 PM
Tribalheads
09-29-2015 03:24 PM
09-25-2015 06:05 PM
justin.w13.walker
09-22-2015 02:21 PM
Quick Reply: Ct-e icebox lid rubbing on hood....
