CAI question
Old May 20, 2014 | 08:22 PM
Nick tsx's Avatar
6th Gear
Question CAI question
Hi guys. i have a tsx 2013 and i want buy a cai but when i look on many manufacturer i found nothing for my car . The years before are the same . do you know why.??
So, which brand do you recommend me??
thanks
Old May 21, 2014 | 09:47 AM
optimusaccord's Avatar
If it is the 2.4, should be Injen, aem, or takeda should all be fine.
Old May 23, 2014 | 01:17 PM
Cu2Suspect's Avatar
x2
Old May 25, 2014 | 05:50 PM
Mr. TTL's Avatar
I have the AEM on my 2012.
Old May 25, 2014 | 11:14 PM
rawger's Avatar
Will a CAI void warranty?
Old May 26, 2014 | 12:01 AM
Jaheri_cbp's Avatar
No. At leash it shouldn't.. Hmmmmm.. It's so easy to put back on to stock so that never concerned me.
Old May 26, 2014 | 12:04 AM
Ken1997TL's Avatar
If and only if Acura can PROVE that your cold air intake modifications were the cause of any damage.
Old May 26, 2014 | 08:05 AM
VR1's Avatar
VR1
Itz JDM y0!
Ct-Engineering makes a CAI aswell.
Old May 26, 2014 | 08:36 AM
ceb's Avatar
ceb
Maybe
So if you have a problem, you just put the old one back in? That's warranty fraud and makes you look guilty since there will be lots of toolmarks - even if the CAI didn't cause the problem it'll look like you tried to cover it up.
Nope. All they have to prove is that you modified a system.
Old May 26, 2014 | 09:21 AM
ceb's Avatar
ceb
Most people don't understand that while the Magnusson-Moss Warranty Act protects the consumer from "tie-in" sales ("you have to use Eureka filter bags in your new vacuum in order to keep the warranty intact"), this does not apply to performance parts.
Although the SEMA and the aftermarket industry tries to convince you otherwise, the MMWA allows the consumer to replace an OE part with an aftermarket part that is substantially similar. That means that you can replace an Osram 9004 bulb with a 9004 bulb from Sylvania that is warranted to be a direct replacement.
However, all bets are off as soon as you use anything that isn't a direct replacement. If it is intended to change the performance of a system (a CAI is sold an "improving performance" even though we know that they don't) then all the manufacturer needs to show is that you made a mod that was intended to change the performance of a system and that the aftermarket part could have caused the failure.
The manufacturer is then free to refuse warranty service on that failure. The manufacturer rep (the dealer) is actually required by their agreement with the manufacturer to refuse warranty service if they believe that the mod caused the failure.
Will a CAI cause warranty issues? Probably not but it also will not increase performance. Most CAI actually decrease performance but increase noise.
Old May 26, 2014 | 06:47 PM
Jaheri_cbp's Avatar
Ct-engineering is currently not a safer option in regards to your warranty anymore as honda/Acura no longer honors or sells their products as a "direct factory replacement" (like comptech used to be). Currently the only factory options that honda offers directly for the aftermarket is accessories from their HFP line which includes body kits, bigger wheels, floor mats etc. Acura has similar accessories available as well, but nothing performance oriented anymore unfortunately.
I would much rather re-install the factory intake then drive in with my AEM installed with any warranty issue yes. As crooked as the dealer is I wouldn't sweat it one bit. You seem like a pretty smart guy, enough to know that the stealerships have done much worse to the typical consumer. That being said if anybody is that concerned about their factory warranty being voided by an intake or any aftermarket performance part to simply wait until the warranty is done to make any mods.
P.S. My warranty ended a few thousand miles ago so LET THE MODDING CONTINUE!!!
Old May 26, 2014 | 08:20 PM
ceb's Avatar
ceb
The bottom line is very simple. Depending on the mod and your relationship with the dealer, ANY mod can cause warranty woes.
Choose your mods carefully and make sure that you are both mentally and financially prepared for unintended consequences.
Old May 30, 2014 | 12:30 PM
JayRSXS's Avatar
6th Gear
Cai's are worthless... I'd just get an SRI. The performance difference is minuscule.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
lanechanger
Oct 13, 2015 10:56 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
