brake and rotor help
Old Jan 9, 2012 | 01:23 PM
stunt's Avatar
this is my first post and i was looking for some advise for brakes and rotors for my 2010 tsx 2.4 it looks like there really close to needing replaced and i was thinking if iam going to spend 400 bucks on brakes i might as well upgrade any suggestions or trust worthy websites i can look into. I use my car for a everyday driver but i do a about 95% city driving so i wear breaks out pretty fast ive heard ebc brakes are good which ones should i look into
Old Jan 9, 2012 | 01:29 PM
http://store.excelerateperformance.com/
Old Jan 9, 2012 | 01:34 PM
stunt's Avatar
i forgot to mention iam looking into doing just the front the rears were replaced not long before i purchased the car
Old Jan 9, 2012 | 02:39 PM
spdandpwr's Avatar
^get the stoptech package from excelerate. I installed them on my si and felt much more confident when applying the brakes. The pads have a way more solid and reassuring feel.
Old Jan 9, 2012 | 03:49 PM
stunt's Avatar
so it looks like its 380.00 for front and rear rotors and all 4 pads does this kit bolt right on with no modifications?will they do free shipping
Old Jan 9, 2012 | 03:51 PM
^if you order the correct ones for your model car, then it will fit right out of the box.
Contact Excelerate for shipping prices
Old Jan 9, 2012 | 04:41 PM
Excelerate's Avatar
Former Sponsor
Here is the link to the package:
http://store.excelerateperformance.c.../i-466578.aspx
Id' recommend purchasing the package to get the best deal and you can install the rear rotors at a later date. We do not offer free shipping as the package is already highly discount. You can add it to cart and put in your zip code for a shipping quote though. We do have all the parts in stock.
Old Jan 10, 2012 | 02:30 PM
stunt's Avatar
well i had a mechanic look at my breaks for free and he said i have plenty of pad life left in front and rear maybe its just me but the brakes dont seem to be very good on the tsx
Old Jan 11, 2012 | 12:25 PM
Excelerate's Avatar
Former Sponsor
These components aren't just more durable; they also perform better. The pads have a higher heat temp range and are less prone to brake fade. The rotors have a power alloy composition and help reduce heat and gases built up at the center of the rotor.
Old Jan 12, 2012 | 08:04 AM
HeavyDuty's Avatar
WTH happened to my garage
FWIW, did your tech look at the inboard rear pads? This was my rear pads at...12 or 15,000 miles? The inboard is on the right.
Oh, and yes, the stock brakes suuuuuuck.
Old Jan 13, 2012 | 04:54 PM
musty hustla's Avatar
The pads I'm not worried about...but are the rotors difficult to remove on a TSX?
Old Jan 14, 2012 | 07:17 AM
HeavyDuty's Avatar
They're floating rotors, bolted to the hubs with #3 phillips screws. They're best detached and reattached with an impact screwdriver. You can get a Mickey Mouse one at Advance, O'Reilly, etc for about $8-$10. The guys at the counter *should* be able to show you how to use it.
Basically you place the driver on the screw & strike it with a medium size hammer & it twists to loosen or tighten on the other end.
Old Jan 16, 2012 | 08:13 AM
stunt's Avatar
iam not sure if they checked the inner pads or not but it feels like i have brake fade already with 21,500 miles on the car and i feel a small vibration when i brake at 50mph they claimed the pad had plenty of life and rotors were good
Old Jan 16, 2012 | 08:23 AM
stunt's Avatar
i still might pick a brake set up like excelerate has once unlce sam give me my tax money back seems like a pretty good price now if i need new pads in the future do i have to use stop tech on those rotors or will any brand like hawk work ok
Old Jan 16, 2012 | 09:24 AM
HeavyDuty's Avatar
Since you have a '10, you might want to look at my gallery for the revised caliper pin locations for the rear brakes. If any questions just PM me.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
