Aftermarket intake manifolds available
We can put any k series intake on our cars with available adapters post pictures of anything you can find that we can use.
PRL adapters (super nice well made)
Fake skunk I think
Real skunk
OBX ITB's
Fake skunk I think
Real skunk
OBX ITB's
I think robpp is referring to the lack of flash pro for the 2011 and later ecu. Not a HP gain. The issue I see with most of the manifolds available is that they increase the torque too far up the rev range. Some even lower peak torque. The tsx needs as much help as it can get for torque low in the rev range.
I don't think so. Personally I'm praying that hondata will continue developing for the rest of the years, especially the '12 automatic. ( I'll bet robpp is right there with me!)
I would bet the hardware is the same or very similar and that the issue is software.
robpp (05-02-2013)
Snorlax (06-19-2013)
Skunk2 PRO Series (knock off installed) $ 235.00
Installed with no adapter filled water port with epoxy to match the 2009-13 tsx P2R intake manifold gasket no leaks worked great cost $6.00 gasket was $40.00
The stock throttle body fits no adapter needed will need gasket with no idle air port cutout just the big round hole cost $ 4.00
Can use Acura ZDX throttle body it is 72mm the skunk2 manifold is machined for up to 72mm throttle body (I will be getting one soon to try before I hit the dyno)
The stock injectors dont fit into the manifold holes can use them if fuel rail is spaced up so they seal on top of the hole I did this and drove it for 2 weeks it was ok, most all intake manifolds for the k series have the small 14mm injector hole ours are about 15.5mm, the correct injectors fit the 2006-11 Civic SI but the wiring plugs must be changed (the bosch 1000cc injectors I used did) all k series fuel rails have 14mm hole (use 14mm top and bottom injectors if replacing)
The wiring to the throttle body was way to short was able to open up the plastic wiring holder on the driver side of valve cover and pull the wires out no cutting wires needed
Driving impressions much better throttle response reves to red line does not choke out like it did with stock intake was well worth the under $300 price tag (with stock injectors and fuel rail)
Are you still running it NA with this manifold? I know you are build a turbo kit for the car too, so I just want to be clear on the application.
Also to be clear, you have replaced the stock fuel injectors with 14mm tops and bottoms that require alteration of the wiring to work?
Injectors are bosch EV 14 modified to 1000cc 14mm on both ends had to put new plugs on the stock wiring to match the injector plugs
http://stores.axionind.com/-strse-23...RBC/Detail.bok
Has anyone seen this? was wondering if it's worth getting if I'm only running an intake?
It really changed the attitude of the engine in a good way
Skunk ultra manifold
I want one of these,if for nothing but how it looks, and testing send me one please Skunk2
http://store.skunk2.com/engine-tunin...-manifold.html
rcs86
08-02-2016 06:52 PM
