RCA Out of the Radio
Old Sep 24, 2009 | 10:57 AM
greg6510's Avatar
Hi there.
Could someone please assist. I have installed external amps, and run them with a line out converter (taking the standard speaker wires and converting them to RCA Outs).
Does anyone know if there are any RCA outs on the radio? This will help me to connect the external amp the proper way, and not through a high/low converter.
I know the previous gen Accord had RCA outs somewhere just around the gear lever, but with the new Accord (CU2), I am not too sure.
Thanks.
Greg
Old Sep 25, 2009 | 11:34 PM
mercman's Avatar
No RCA outs on the TSX. The line outs from the HU to the factory amp are balanced like the previous generation TSX system. I have not had an opportunity to measure the HU signal in the base.
Running an amp directly off of the Tech HU is currently impossible, but I am working on it.
Jeff
Old Sep 25, 2009 | 11:42 PM
Tishkevich's Avatar
ed is running one...
Old Oct 12, 2009 | 07:50 AM
bjohnston115's Avatar
you could use the low level inputs that go from the radio to the amp? or is the amp in the trunk only for the sub?
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
