Improving stock audio... What do you think!?
Old Mar 18, 2011 | 10:54 AM
danzz's Avatar
3rd Gear
Hi!!..
Im the owner of an euro honda accord tourer, wich its the equal of the acura tsx sport wagon. In europe we have a equivalent of the ELS, but they say thats its a bose system, but as far as I have checked its a panasonic system.
First of all I thougt of changing the sub, but I had discarted that now after reading mercman posts, I dont want to add any other amp, or losing room in my trunk... Maybe a good choice would be make a close encloser with fiber glass... But can be a hell, and maybe it losses quality even that the bass its improved.
So now my project would be changing the tweeters and the woofers at the front doors.
I was thinking of this speakers wich I already have from a previous installation.
CORAL ELECTRONICS PFK 162
2-way stereo speaker kit
100 watt max power
50 watt nominal power
50÷20000 hertz range
165 mm woofer diameter
fiberglass braided tissue cone
36 mm tweeter diameter
neodymium magnet, silk dome
5000 hertz, 12 dB/oct crossover
hi-pass electronic power control
http://www.coralelectronic.com/pinif...dspeakers/1796
The tweeters are:
CORAL CT 36
210 watt peak power (Pk)
70 watt nominal power (Pn)
5 ÷ 20 Khz frequency range (BW)
90 dB sensitivity (2.83 V / 1 m)
4 ohm nominal impedance (Zn)
5 Khz cut frequency (6 dB / oct)
19 mm voice coil diameter
silk dome material
neodymium magnet material
http://www.coralelectronic.com/ct-36/1790
By the way, I have checked the stock tweeter and they are 6ohm and 15watt, my Coral CT 36 will function properly!?..
Mercman, I seen in a post of yours that you already made the wooden rings for the front doors speakers, can you post a draw with the measures!?.
Every opinion is welcome!!!
Thanks in advanced...
Old Mar 20, 2011 | 06:28 AM
danzz's Avatar
3rd Gear
Tweeters already changed and from my point of view it has improved a lot the sound, now the voices and the high its more silky...
An improvement I highly recommend... it only takes a few minutes...
Now, I must consider if I should changed the woofers...
Anyone knows what RMS receives the front speakers!?.
Old Mar 21, 2011 | 10:13 AM
mercman's Avatar
Originally Posted by danzz
Hi!!..
I have some PDFs that you can print and use as templates, I also have the measurements somewhere, I’ll have to dig them out.
Jeff
Old Mar 21, 2011 | 11:12 AM
danzz's Avatar
3rd Gear
Jeff
That would be great!!!... Thanks in advanced!!!!..
Old Mar 27, 2011 | 11:48 AM
mercman's Avatar
I found them, drop me a PM with your email and I will send them to you.
Jeff
Old Apr 9, 2011 | 11:19 AM
Limitor's Avatar
Hii,
I am from Turkey. ı am owner of euro honda accord 2.0
I have done some improvments with stock audio today, like mercman.
For front
Alpine sgp-17cs compenents
max 280w
rms 70
Old Apr 9, 2011 | 12:08 PM
Limitor's Avatar
Hii iam from Turkey and i have euro honda accord 2.0
Today i have improve stock audio, like mercman style.
For front
Alpine spg-17cs (compenents)
  • 17cm (6.5") component speakers
  • Peak Power: 280 W
  • RMS Power: 70 W
  • Polypropylene Cone Pearl Mica Injection
  • 20 mm Silk Soft Dome Midrange
  • Voice Coil Type: Square Voice Coil Wire
  • Frame: Injection Mold Frame
  • Design: Long Excursion Design
  • Magnet: Ferrite Magnet
  • Woofer Mounting Diameter: 14.1 cm
  • Woofer Mounting Depth: 6.1 cm
  • Frequency Response: 68 Hz to 20 kHz
  • Impedance: 4 Ω
  • Sensitivity: 88.5dB / W (1m)
for rear
Alpine sxe-1725s and spg-17c2
17cm (6.5") coaxsiel speakers
Peak Power: 240 W
RMS Power: 60 W
After the install,
I think the bass sound loosen.I dont understand why?
But the general, the sound is more clear than factory speakers.
Are there any one has opinion that the factory amp rms power.May be it is smaller for these speakers...
Mercman, are yoo meet this sound problem with your system with polk audio ?
I can answer your questions for install.
Thanks all.
Old Apr 9, 2011 | 04:08 PM
mercman's Avatar
I don’t know what audio systems the Accords use but if you just changed the speakers and have lost some of your bass then I would check the wiring and make sure you didn’t cross the phase (+/-) wires.
Also check that the drivers are sealed in the doors and that there are no gaps for air leaks.
Jeff
Old Apr 10, 2011 | 06:55 AM
Limitor's Avatar
Jeff
Hii,
I check the wires.I cant find any problem with phase (+\-) wires or gaps for air leaks.I think it is related betweeen coaksiel spekars.The coaksiel spekers bass sound is less than factory speakers.They are giving mid sounds.I want to ask that, Did you changed all of the speakers ?, Are threre any solution to change the sub with another brand like alpine? My car has panasonic amp system but i cant find the values of rms for it.Which amp and which values of rms, the Acura uses ?Thanks for your answers.
Old Apr 10, 2011 | 06:55 PM
mercman's Avatar
Originally Posted by Limitor
Hii,
I’m not sure how you connected the new speakers to the factory wires but in the states we have adapters available that just plug in so you can’t flip a phase. If you did not use the adapters then you can check the phase by looking at the factory speaker plug. If you hold the plug so that the alignment tab is facing down when you look at the contact side then the + wire is on the left of the connector.
I know you said you had the factory Panasonic amp but is it the ELS or the Premium audio system?
I’m working on a solution for the sub with the goal of keeping as much trunk space as possible and getting real tight bass. I’m not looking to make it thump.
Take a look.
https://acurazine.com/forums/2g-tsx-audio-bluetooth-electronics-navigation-304/rear-package-self-removal-sub-replacement-813607/
Jeff
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
jmaxima03
Sep 27, 2015 10:22 AM
rangomango
California
Sep 24, 2015 05:47 PM
