How do I make the Nav Screen Auto Dim? (2009 TSX)
Old Jan 1, 2009 | 09:24 AM
djrayray's Avatar
Question How do I make the Nav Screen Auto Dim? (2009 TSX)
I have the new 2009 acura tsx tech. how do I make the Nav screen auto dim? I tried to roll the brightness dile back almost all the way and it still stays bright in the night time. Am I forced just to used the moon sun icon on the dash? My wife has an 2009 acura RDX and the auto dimming works fine. It also worked fine on our 2006 acura tsx. How do you make this work?
Old Jan 1, 2009 | 10:18 AM
MMsTSX's Avatar
JDM Addict
hmmm...
well, I guess it's activated a different way on the 2009.
this would be a great time to read your owner's manual.
Old Jan 1, 2009 | 12:29 PM
Luchin's Avatar
If you use the dimmer switch to turn down the dash lights, the next time you start your car you Nav screen will automatically dim. Not a good thing if you have dimmed your lights for night driving because the Nav screen in almost invisible during the day. The only other way is to use the button on the dash with the sun/moon symbol on it. Push this button and you can dim or completely turn off the screen.
Old Jan 2, 2009 | 05:50 AM
TheGoodGuy's Avatar
i thought there was a brightness control for the navi itself, check up on menu/info screens..
You should be one less than full brightness for the auto dim to work.
Old Feb 12, 2009 | 10:59 AM
llcooljayce's Avatar
Does anyone have a solution for this? My stand alone GPS auto dims ... I can't see why the TSXs GPS couldn't do it as well ...
Old Feb 13, 2009 | 12:07 AM
TheGoodGuy's Avatar
Read the manual. My car auto dims when the headlights come on (in auto mode on the stalk). You got something setup wrong.
Old Feb 13, 2009 | 03:19 PM
DomSim's Avatar
4th Gear
try this, worked for me: have the brightness dial clicked all the way up, turn on the headlights, then turn the dial back from full. you should see the screen dim auto now. if you read the manual, it states that if you hit the display button and switch it manually it will not switch auto until the car is turned off and back on.
Old Feb 13, 2009 | 03:55 PM
Colin's Avatar
Welcome to Azine.
Old Feb 19, 2009 | 07:36 PM
DomSim's Avatar
4th Gear
thanks
Old Aug 1, 2009 | 11:33 AM
bignips's Avatar
is the navigation screen supposed to automatically change to the night mode when the headlights come on or when the light sensor tells it to?
Mine hasn't been and I find it pretty annoying to have to do it everytime I get in the car.
Old Aug 1, 2009 | 03:43 PM
B3RRYKOOL's Avatar
yea it should. if it doesnt. then theres a problem..
Old Aug 1, 2009 | 09:19 PM
GrigioX's Avatar
you have your instrument panel brightness set to full. twist it one click to hte left and your nav screen will go into night mode when the headlights come on.
Rocktman1
Oct 31, 2015 02:33 PM
PortlandRL
Sep 14, 2015 12:01 PM
TSX 09
Sep 6, 2015 01:07 PM
andysinnh
Sep 5, 2015 11:38 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
