HFL Question
Old Apr 27, 2010 | 06:48 PM
Lexusconvert?'s Avatar
HFL Question
Does the TSX Tech have the speed dial option on its bluetooth that the TL does. Also can you use it by voice and not by using the buttons on the dash. I am really interested in the new TSX and hope it has these features.
Old Apr 27, 2010 | 07:27 PM
FuzzyLabRat's Avatar
So, as I've discovered after being told, you can save entries to a phonebook and dial them by name using just the voice command and HFL buttons.
Can you explain what the speed dial function of the TL is -- I'm not familiar with it.
Old Apr 28, 2010 | 08:37 AM
You can add 4 numbers that you can dial without going through the phonebook.
Old Apr 28, 2010 | 05:48 PM
http://www.youtube.com/watch?v=Xr7_dxB4Bn0
Old Apr 29, 2010 | 10:57 PM
Dang... i like that interface much more than the one in the TSX; I always want to navigate and dial etc using the screen instead of the multi-info display....
Old Apr 30, 2010 | 02:24 PM
You cant use the Nav to make calls in the TSX.
Old Apr 30, 2010 | 02:32 PM
ccarbajal08's Avatar
OCD in the OC
Yes you can. You can even place calls via voice-command.
Old Apr 30, 2010 | 03:29 PM
NorCalTSX09's Avatar
You can import your contacts via bluetooth to the Nav, then search the phonebook, etc. This is separate from the HFL phonebook mechanism, I think.
Haven't done it yet, but you can program the HFL phonebook with voice for your contacts. That way you can use voice to dial whoever you've programmed.
Old Apr 30, 2010 | 03:33 PM
Lexus, just saw your other thread. Going to give the voice tagging a shot in the Nav phonebook.
Old May 24, 2010 | 06:09 PM
But you cant dial # by # with the nav can you.
Old Jun 1, 2010 | 08:29 PM
DJMcGee's Avatar
No, the TSX nav/bluetooth does not allow # by # dialing. You can use the keypad on your phone for that.
Old Jun 1, 2010 | 09:04 PM
No1nfoProvided's Avatar
You can by voice over bluetooth. Some people say that their TSX picks up the wrong numbers all the time, but mine is fine.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
