Help installing audio system
Old Aug 11, 2016 | 11:32 AM
angeljr8282's Avatar
How it going guys I have a tech package tsx and want to install a system using my stock head unit is there any DIYs out there showing where to grab the sign to install Amps
Old Aug 11, 2016 | 11:33 AM
you can either do it by taking the signal at the sub(if you have a sub) or direct from the amp.
Old Aug 12, 2016 | 07:43 AM
D4nnyD's Avatar
Depends,
if you just want to add a subwoofer then do what ^^ he said and use a line out converter to get your line driver signal.
If u want to add / replace full range speakers with an amp, then you need to take the signals from the output of the stock amp. You will need some sort of signal summing processor such as the JBLMS8 to use as a line driver for your aftermarket amp.
Search MS8 in this section of the forum, someone here has done it before and should have a wiring diagram for you to use.
gavriil
Apr 1, 2026 12:45 PM
TSX69
3G RLX (2013+)
1409
Aug 17, 2020 12:49 PM
Feb 20, 2019 08:58 AM
00TL-P3.2
Feb 11, 2019 11:23 AM
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
Sep 17, 2018 07:45 PM
