Both Front Passenger Window and Sunroof will not respond to ANY controls.
Old Feb 22, 2017 | 01:16 PM
2011TSXer's Avatar
This above issue appeared at the same time. The Front Driver's Window also has some issues when I try to send auto up/auto down.
Old Feb 22, 2017 | 01:17 PM
Have you checked your fuses?
Also what car do you have? Your user name and the subforum in which you've posted does not match.
Old Feb 22, 2017 | 01:21 PM
2011TSXer's Avatar
thoiboi,
Sorry for the confusion. I'm a Newbie. I have a 2011 TSX 4 Cyl w/Tech Package. I have not done any trouble shooting as of yet. Just trying to gather some info first.
Old Feb 22, 2017 | 01:22 PM
Gotcha,
we'll have it moved to the TSX forum. But it's going to be one of your fuses if i had to venture a guess. Check them all
Old Feb 22, 2017 | 01:29 PM
projektvertx's Avatar
Moved to the TSX subforum. Thanks for the alert and hopefully the TSX members have a fix for you
Old Feb 26, 2017 | 06:23 PM
Atron483's Avatar
Hello, this is my first post! I just had a similar issue both front windows not working rears were fine. Didn't try the sun roof.. Anyways I was working on the car and the battery had run down to 10 volts. As soon as I put a charger on the windows all worked.
See if your battery is dying, or try them with the car running, if you haven't already.
TSX69
ZDX
70
Oct 10, 2013 08:20 AM
rfrys
Apr 26, 2006 10:57 AM
vp911
Jul 7, 2005 03:52 AM
gavriil
Nov 21, 2003 10:17 AM
