All speakers being replaced.
I called Burrard Acura and explained the problem I was having with my speakers. Apparently they have something that tells them to replace ALL the speakers in the car. So since my two front speakers have been done I will be going in on Wednesday to have all the rear speakers replace.
Both back door speakers, the sub, and the two other speakers in the rear parcel shelf.
And Campus Honda was trying to insinuate that I was pushing too much base through the speakers. Good to see they haven't changed since I had my 97 Prelude.
Yeah me too. This problem is taking away the joy of owning a new car. I'm sure we will get there. The fact that they are acknowledging that there is a problem and that THEY want to replace all the speakers gives me hope.
[QUOTE=TSXfreeko;11813165]Luchin, could you please describe the exact problems you are experiencing with your speakers? For example, is the sound crappy/distorted all the time, or just occasionally with certain heavy bass sounds etc?? Is it much worse in some speakers than others? Thanks[/QUOTE
The sound is fine until the speakers blow, then they sound distorted. Plus I have rattling in the doors, and rear shelf. Popping sounds when I use the balance control to isolate which speaker is blown. The last time my speaker blew I wasn't getting any sound from the rear speakers and then when I did get sound it was crap.
Are you diagnosing or just curious?
Do you drive a TSX? If so which model?
My wife has a Premium and she blares her music with no trouble at all. I listen to my music so that it is backround sound. Volume 8-10.
The TSX Tech and TL Tech suffer from the same problem.
[quote=Luchin;11813559]
Thanks for the response. I have the TSX tech. I had two door speakers replaced, they were clearly blown. It seems everything is ok now..... most of the time. But I do hear obvious distortion (buzzing/vibration) from one of the other speakers at higher volumes (20-25), when there is a strong bass surge. I'm just afraid that its only a matter of time before it (and the other speakers) blow completely. Not a good feeling.....
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
rboller
09-23-2015 02:49 PM
