2012 Base TSX Cluster to 2012 SE TSX cluster? Is this possible.
Old Aug 22, 2014 | 12:21 PM
Glepage22's Avatar
Hi,
I want to know first, does the Acura TSX SE come to Canada ?
If yes, Can I swap de cluster from a 2012 TSX SE in my 2012 TSX Base? If yes, does it is plug and play?
Thank you for your help guys and girls.
Guillaume
Old Aug 22, 2014 | 12:45 PM
xtcnrice's Avatar
VTEC just kicked in, yo!
Acura TSX SE does not exist in Canada. Our equivalent is the Acura TSX A-Spec. You can swap clusters, but I'm not sure if the mileage is based on the car or on the cluster itself. There are threads about this... definitely do a search. It should be plug and play. Good luck finding an A-Spec cluster (km/h vs mph, km vs miles, etc.). If you're just interested in the red lights, you can get a USDM Acura TSX SE cluster and swap the lights and stuff into your existing cluster. Quite an expensive mod though. I think kostantinos did this mod. Again... do a search.
Old Aug 22, 2014 | 01:23 PM
Glepage22's Avatar
Ok, great! Thank you sir.
I will do my homework.
jriv7
May 8, 2020 05:50 PM
Sep 17, 2015 10:16 AM
nash3222
Sep 10, 2015 09:46 PM
kuzdu
Sep 10, 2015 08:42 PM
