Wiring dash cam to rear view mirror power supply
Old 07-18-2017, 07:59 PM
8th Gear
landser1111's Avatar
Hi there everyone, I am interested in installing a dash cam for my TSX but doesn't want to deal with all the long wirings... Is it ok to hard wire the dash cam onto the rear view mirror diming power supply? I believe the wire is protected by a 10A fuse? Thanks in advance guys.
Regards,
Old 07-18-2017, 08:25 PM
Received 8,632 Likes on 6,667 Posts
Sure. They have things called mirror taps for this exact purpose
Old 07-19-2017, 07:18 AM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Not sure if the rear view mirror wire is hot only when ignition is on, or always on. If it's the former and your dash cam has a "parking" mode, you may not be getting the power you need when the car is turned off. If this is not a feature you care about, then this should be fine.
Old 07-21-2017, 11:49 AM
TSXV6Guy's Avatar
I have done it (powered only with ignition) and it works great.
