Windshield Washer motor hosing configuration
Hi everyone, I had to replace my windshield washer reservoir because it was damaged. The old unit had one tube out of the motor/pump, connected to a T. The new unit has a white and a black outlet tube. I can't figure out how to connect the hose which goes to the nozzles and should I plug the other tube? Thanks for your help.
Is this for a Sport Wagon? Sounds like you might have an incorrect or generic aftermarket replacement part. Is there a part number on the new washer pump, or can you post a picture of it? It would probably be fine to connect the front hose to one pump outlet, and the rear to the other, but a pic would help.
