Wheel alignment report, is this acceptable?
Old May 21, 2012 | 12:03 AM
hcp's Avatar
hcp
Hi there.
I hit a nasty pothole during the winter and since I was around Sears today, I requested a wheel alignment check/service. When driving, I did not notice my car pulling to the left or right, but I decided to have it checked/serviced anyway...
Here is the report:
Is this acceptable? I didn't read the report until I got home. When searching the web, I read that caster cannot be adjusted. However, I do not understand why other settings were not tweaked and why is it that front cross camber was 0.0 originally and -0.4 now?
Thanks in advance!
Old May 21, 2012 | 12:22 AM
odus's Avatar
is your car lowered or stock?
Old May 21, 2012 | 12:26 AM
hcp's Avatar
hcp
Car is stock. I just got new wheels but they have the same specs as stock wheels and I'm using stock tires.
Old May 21, 2012 | 05:43 AM
Robert4's Avatar
Those numbers are ok. The low caster on the right front would only be a concern if the car pulls or drifts to the right. The front camber readings changing is most likely from the tech getting in the car to center the steering wheel. The right rear low camber should not be a problem.
Old May 21, 2012 | 06:26 AM
TLtrigirl's Avatar
3G TL/2G MDX Owner
alignment machine not calibrated??
Old May 21, 2012 | 09:39 PM
hcp's Avatar
hcp
Thanks for the answer. Car drives normal and doesn't pull or drift to the right...
james357
Feb 13, 2016 02:37 PM
Zonian22
Nov 14, 2015 01:20 PM
GhostTL09
Sep 19, 2015 01:57 PM
PortlandRL
Sep 14, 2015 12:01 PM
Zonian22
Sep 2, 2015 08:19 AM
