TSX dash rattle
TSX dash rattle
My car just TSX just recently started doing this. I hear a rattle in my dash and it's coming from the driver side. It sounds like it's close to me. It sounds like something broke in my dash and it bounces. The doesn't occur everytime I hit a bump but it occurs when I do hit a bump. Kinda like when you hit a bump and your car bounces. I looked under the dash by the gas pedal. Nothing is broken or loose. I tried hitting the dash but no help because I don't know it's exact location. But it is coming from the dash. You can tell it is. What could it be?
Received 7,772 Likes
I notice a metallic rattle or jingle every once in a while. Ended up being the loose coins I have in the little pop-down cubby off to the left of the steering wheel.
OP, you're gonna need to keep trying to replicate it. We can't do much over the internets just by your vague assessment... Not bashing, just saying it's a hard problem to solve with little info.
Go find a parking lot with some speed bumps and see if you can narrow down where it's coming from?
ROTAREDOM
Mine was a pen that got hidden in the cuby area next to driver side leg and trim piece. I also found my small screw driver that I had lost for 2 years in that same spot
I emptied out my car and even little piece of paper... there is still rattling noise near the driver side speaker.... it seems as if something is loose...
It doesn't happen all the time but when I do boost up bass, hear the rattle... and sometimes on the bumpy roads...
help?
help?
Shank009
10-27-2015 07:33 PM
