Software updates for TSX? Would it be possible?
Robbie D.
I know alot of the TSX's features such as steering, suspension and engine are controlled by a computer with software written by Acura.
Would it be possible for Acura to release updates (much like those on smartphones) that would address some of the minor annoyances we're having with our cars?
are there any car companies that have done this? I know Ford has their Sync system with Microsoft which will receive software updates. But haven't heard of any companies updating software for drivetrain, steering, etc.
Very unlikely. They might make a change with a new MY, but running updates would 'smell of a recall' and that would not be a good thing.
Updates are done ALL the time. Car has a rough idle. The manufacturer works on a software fix and releases a flash update to the dealer. Power sliding door on a mini van may reverse too easily. Manufacturer works on a flash update and releases to the dealer. The list is endless. If and when Honda finds the cause of the pinging issue that some TSX's are having,I'm sure it will be a flash update of the PCM.
software is improved all the time....getting it updated on your car is a whole different story. on my Audi A6, I was able to find the firmware discs online and updated the MMI since a dealer won't do it unless you have a legit issue that would require it. I'm sure someone, somewhere has update discs for Acura as well. Just for bluetooth compatability alone i'm sure the software is upgraded. The problem would be getting your hands on a disc and a how-to.
Bluetooth shouldn't need any kind of update since the spec is published and Acura follows it. It is up to the device manufacturers to upgrade their devices to adhere to the BT standard. (Palm 600-650 were especially bad on certain carriers).
As I understand it, most of the flashes are done with a windows tablet computer which only dealers have. I think the p-rom flashes are downloaded to this directly from Acura. I could be wrong, but I am 99% sure that they don't use discs these days (except maybe for navigation).
Robbie D.
thanks for all that info. i never really knew you can fix things just by updating software on the vehicle's computer.
hopefully acura will take care of the pinging and steering problems.
GWEEDOspeedo
01-15-2016 10:39 PM
