Replacing my DRLs with these
Hi guys,im looking for a LED replacement for my DRLS which will have a good highbeam out, so im thinking about replacing my DRLS with these
https://www.theretrofitsource.com/le...l#.Vq48EDYrLnD
Has any bought and tried these?
Also does anyone have another DRL LED white replacement they use that has a good highbeam output?
As far as I know, no one has purchased and tried, or at least purchased, tried, and shared results.
I'm curious to know if they are truly plug and play w/o any issue or flicker.
The flicker on DRL's is usually due to the DRL circuit only providing 5-6 V (aka about half the normal voltage) In a halogen bulb, this means less light. LED's require ~12 V. If you don't want flicker on any DRL LED bulb, you'll need to install a relay harness. Load resistors trick the computer into thinking there's a bigger load on there and the DRL light on your dash disappears. Those are some solid bulbs, I'm not sure there are resistors involved and also relay would mean it would always be on full power. 'high beam' functionality would effectively be non-existent as the DRL will always be in 'high beam' mode. Unless they start having 'dual filament' LED technology you won't get the exact result you want
Installed these bulbs and they work great! When in highbeam mode they are very bright... the first led DRL that actually has a good highbeam output....
The only issue is that my check DRL light is still on...
I am using this Decoder off of my old led DRL set up...
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Which kit is that?
It is from this website
Acura Honda Lexus High Beam LED Daytime Running Lights Decoder Modules
(R2 Decoder)
I thought these were the resistors.. because on my old LED drl's these worked fine.
(R2 Decoder)
(R2 Decoder)
Have you tried emailing the store? It does say they tested with our vehicle. Maybe they can offer some troubleshooting and you could share it with us.
Are you setup like this: Install LED Daytime Running Lights with special DRL Decoder
Edit: After looking at the diagram, it looks like the "decoder" is a pair of resistors.
Army
4G TL Problems & Fixes
04-28-2021 08:14 PM
MikeekiM
04-18-2016 01:07 AM
