Replace HID Bulbs
8th Gear
Replace HID Bulbs
I got a set of 5000K Morimoto Bulbs for my TSX recently. Last night I tried to replace the oem bulbs with the new set but ran into difficulties.
First, I followed the owners' manual by removing the one screw and one clip from the wheel well area. However, when I tried to peel down the wheel well liner, I can only open up a couple inches of gap for me to barely stick my hand into it, which I don't think I can replace the bulb with blindness (cause I can't see the bulb area from the gap I created). Also, the wheel well liner material is so hard that I'm afraid that I will break it if I pull it down further. Is it because of the cold weather? Will the material be soften if it's under warmer temperature?
With no success in option one, I tried to do it from above. Well, the space is not that great either from above. I started with the passenger side. I could barely twist off the cover, got to the ignitor part. After I twisted off the ignitor, I couldn't put it out of my way cause the wire attached to it is just too short. The ignitor just blocked my way to the bulb clips. So I stopped at this point. I know that the driver side should have a bit more space after I remove the battery, but I didn't try cause I know I will run into the same problem when it comes to the ignitor part.
I know it shouldn't be that hard to replace a bulb cause I've done many many times for halogen bulbs. Could anyone shed some lights for me in this case?
-I need to know if I should work from above (from the hood) or work from the wheel well area.
-How to put that ignitor away so I can get to the bulb area.
-Please feel free to let me know if I've done anything wrong during the process.
Thanks!
Wahboy
Thanks!
Wahboy
I still don't understand why people replace their OEM bulbs in the 2nd gen TSX...
Everyday I'm rofling
I recently also bought 5000k bulbs, but I ended up keeping the OEM ones in for time being. I ended up going through the hood area so I didnt have to take off my bumper. I did the whole thing blind. Unless you have taken apart the light assembly before(I did when I cleared my headlights) then I would think it would be next to impossible for you to do it blind. I was pretty familiar with it, and it took me some time for me mess around in there and hope i had everything lined up perfectly and put it back together.
David_Dude
^ but they reduce effectiveness compared to OEM. The TSX has very nice output by the design actually as a whole Acura makes some pretty good projectors. IF i were going to replace new bulbs in a new car, it'd have to be a step up from OEM (lumens, not color) and the best that i've seen is the Osrams CBI's. They have the same brightness as the Philips, maybe even brighter (judging off the 3G TL, not sure if philips are used for the TSX), but they're 5000K. It doesn't get no better than that. Brighter light and a slightly different color. Usually they higher the color temp (i.e. 6000K vs OEM 4300K) the light output is compromised, especially in adverse weather.
But they're switching to 5000k which is essentially the same as oem. I would assume the output isn't as good compared to oem, but I have a set of morimotos myself and they're great. So bringing me back to the post: why are you changing out your oem hids?
AZ Community Team
I have no idea why people put those higher temperature lights in their cars just to create a blue or purple light. I've been in a car like that before (10,000K) and the road wasn't visible at all.
Thanks!
Wahboy
Thanks!
Wahboy
I also changed mine with a pair of Morimoto 5000k. As for why, well i like the look of pure white then an off white with a hint of yellow.
As for lost in output, I modded my projectors so I have little to no lost in output.
I just took my bumper and headlight off and it was a piece of cake. But the "string" that's preventing you from pulling the bulb all the way out is attached to the socket. If you accidentally pull it to hard and it comes off you can just push it back in. At the end there's a thin piece of metal that sit between a clamp on the head. I might have a picture of this, I'll upload it tonight if i can find it.
drivedata (11-21-2012)
David_Dude
I've never seen the morimotos in action before, but if I was to upgrade bulbs on any HID equipped car (2G TSX's are new) it'd be with a higher or equal quality bulb that can put out more light. Osram's CBIs and SVS' fit the bill. OE bulbs ftw!
2010 TSX
HELP
Thanks!
Wahboy
Thanks!
Wahboy
thanks
Received 7,772 Likes
OP might not get around to answering you... He hasn't logged on since June of 2013.
Sorry.
I just picked up a 2013 on Saturday and can't get used to the lights. They seem wonderfully bright but there is a sharp cutoff of darkness. Do you recall a learning curve when it comes to getting used to them?
Maybe swap them out for some halogen headlamps, i'm sure someone here would trade you in a heartbeat
Well I can't really speak on behalf of you but it's a great feature. HID projectors headlight technology is leaps and bounds above standard halogens and I've done multiple projector retrofits to get away from halogens. The trend is going that way, the light is better focused and brighter.. It's really a win-win.
I'd say get used to it because it's not going anywhere.. after that will be LED and laser technology
