Removing Front Grille
Hey what's up guys, found some info but wanted to know if it was possible to remove the entire grille without removing the bumper off the car... Want to get it paint matched along with my rear window spoiler and it be easier to just drop both things off at the shop then re install... I have a 2010... Any info is appreciated .. Rather avoid dropping the bumper if possible
TSX AMG Type //M i-VVT
I had to pull the whole bumper off to get the grille off when I wanted to wrap it.... I didn't see any other way.
Everyday I'm rofling
Just remove it and do it the right way.
Wrap chain around pole and thread it through grille
Get in car
Start car
Put car in reverse
Step on gas pedal
Put car in park.
Get out of car
Pick up grille. Remove chain
Simple. To remove the whole bumper is equally easy. Find a parking block that is higher than the bottom of your bumper (very easy to do if your car is lowered).
Drive over parking block until front wheels touch block. Don't pay any attention to that scaping sound - it is merely prepping your bumper for removal.
Back up quickly.
Pick up bumper from ground.
Find telephone pole.
Get in car
Start car
Put car in reverse
Step on gas pedal
Put car in park.
Get out of car
Back up quickly.
Get in car
Start car
Put car in reverse
Step on gas pedal
Put car in park.
Get out of car
Back up quickly.
Hmmmm seems like a good idea but my car doesn't have "Park" so could u explain how to do it with 3 pedals? I think my car is broken
You're screwed, you'll never get the bumper or grille off.
BTW - Mods - these instructions need to be a sticky.
Back on topic - I think it is far easier (and far less bloody) to take the bumper off. Just spread a blanket under the bumper as you are working with it to catch any loose screws and to keep the bumper from getting scratched once removed.
Wash the car before you start this work.
Whaaaaat???? Your car doesn't have "Park?"
Nuts! Screws, clips, retaining rings, chewing gum - something is holding the bumper on and something can be dropped. Maroon!
It is so nice to be loved. You guys are just green with envy because I know stuff you don't. There is you ending color - GREEN
TLDude876
12-28-2016 03:18 PM
