Oil change?
Old Sep 29, 2012 | 01:52 PM
IndycarFaster's Avatar
Oil change?
Hey everyone, just wanted some recommends on oil change process. Is it possible to change oil on 2012 tsx without ramps or jack? I used to do this on my civic easily but not sure if Incan maneuver the tsx. I would prefer to do it with ramps but have heard jacks are easier. Thoughts? I see the ramp as easy to drive up, put wheel blocks down and get under there quick. Thanks everyone.
Old Sep 29, 2012 | 01:56 PM
imKing's Avatar
I personally would just jack the front up, put a blocker infront of the tires so they car doesnt move when trying to get the filter out and u should be good.
Old Sep 29, 2012 | 02:14 PM
That would be easiest. I worry about the jack points of the car though for some reason.
Old Sep 29, 2012 | 02:50 PM
ed_423's Avatar
SeeYou2Crew #2
i personally prefer jacks haha
Old Sep 29, 2012 | 02:56 PM
EzeE1o's Avatar
Just lift the whole front end at the front cross member then put the jack stands on the side jack points. Only takes 2 min if that.
Is your car an MT or AT? I wouldn't do the ramps with an MT
Old Sep 29, 2012 | 11:59 PM
PyroDave's Avatar
i've done ramps and jack, i prefer jack. the TSX is too low for alot of ramps, and lining them up is a bitch. theres 2 DIY's up and i believe they show the right place to jack it up
Old Sep 30, 2012 | 09:20 AM
stan_t's Avatar
I did mine on ramps, but either way should be fine. I doubt it's possible without lifting the car even if you really wanted to -- the filter is under the engine.
Stan
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
