Master window switch
Old Jul 14, 2019 | 10:25 AM
KJEFFERIES68's Avatar
6th Gear
Good Morning
Not knowing my own strength. I pressed my driver's side window switch and now it will no longer work.
What do I need to replace to fix this issue?
Old Jul 14, 2019 | 01:02 PM
01acls's Avatar
You need to replace the switch assembly. The switch panel just snaps in at the front so get under the front part and unsnap it and then slid it out.
The switch is held on by a screw so remove that and the switch will separate from the switch panel.
Old Jul 15, 2019 | 09:46 AM
TSX1012m6's Avatar
Before you replace it, try to disassemble it. I have taken mine apart and needed to clean and bend the pins that make contact from the plastic switch to the main board. It's very easy to do, don't do it while drinking though. You can fix this for free. If it still doesn't work then replace it.
Old Jul 15, 2019 | 09:48 AM
6th Gear
Thank you
Next time I wont drive while mad...
Old Jul 16, 2019 | 08:51 AM
cu2wagon's Avatar
FWIW, the switch box underneath the plastic valance on the armrest of the TSX is the same as the 3G TL. Ebay/junkyards can be your friend and that broadens the search parameters for more/cheaper options.
Old Jul 16, 2019 | 09:34 AM
6th Gear
Oh thank you very much. Finding an TSX in any junkyard near me has been a vain search. I appreciate you so much for telling me this
Old Jul 16, 2019 | 09:36 AM
cu2wagon's Avatar
No problem. Somewhere I have pictures, but I can't find them right now.
I bought a TL switch assembly on eBay on a hunch and it was plug and play. Everything worked.
Old Jul 16, 2019 | 09:40 AM
cu2wagon's Avatar
Ah. Nevermind. Here we are. The TL Plastic is different, but the whole switch block unscrews from the back and will swap right over.
USNA93
Jan 17, 2020 12:51 PM
puchak
Oct 28, 2008 09:02 AM
Zigma
Jul 22, 2008 09:33 PM
OntarioTL
Aug 22, 2007 05:29 PM
TwanPD4
Jun 13, 2007 11:05 PM
