Maintenance Codes
Maintenance Codes
Greetings from Europe.
Here Acura TSX is called Honda Accord.
Even though some specs are different and could vary by the model and year the basic principles are the same. I have a question regarding reseting the schedule on maintenance screen. Here is the Symbol Maintenance Item (Codes) for the European Accord.
Symbol Maintenance Items
A Replace engine oil and oil filter
B inspection service
2 Replace dust and pollen filter
Inspect drive belt
3 Replace transmission fluid
4 Replace fuel filter
Inspect idle speed
Replace spark plugs
5 Replace engine coolant
7 Replace brake fluid
8 Replace air cleaner element
9 Inspect valve clearance[/size]
Here is the point: Today I changed both the transmission fluid /code 3/ and replaced the brake fluid /code 7/. After resetting /code 3/ the computer moved me to B which is not due at this point so I do not want to reset it because it will mess up the schedule for it. Code 7 was due to change. As a matter of fact, it appeared few months ago. How could I make code 7 appear again on the dashboard and reset it?!
Thanks.
Inspect drive belt
Inspect idle speed
Replace spark plugs
Thanks.
