Lower Engine Cover Damage Cause
Old Dec 13, 2021 | 02:34 PM
pianos101's Avatar
Slightly different take on the lower engine cover posts.
I recently noticed a metal grinding noise when I would go over a bump or at the bottom of a hill. I just peeked under my car (2012 TSX 4cyl auto) and found the metal part of the splash guard totally mangled.
I'm trying to put together how this can happen, and can use your help eliminating causes:
1) Last oil change was June 2021, at a dealer, so presumably filter was changed. My understanding is that the metal part of the guard has to be removed to replace the filter? They did not disclose any damage.
2) In July, my timing chain and VTC were replaced (at the same dealer). This work sounds unrelated, can you confirm? Again, they did not note any damage.
3) In August, I was in a small accident where someone hit my rear right door. The body work was done in September (just rear door replacement and rear 1/4 panel repair, plus paint, etc.). Nothing in the front or under the hood was touched. The noise started right after I got my car back. But they shouldn't have touched the splash guard I thought.
Any ideas on how this could have happened and/or who should have noticed it in the past 6 months? I don't remember driving over any curbs or anything that caught the edge.
Old Dec 13, 2021 | 05:49 PM
it looks like it was pushed backwards from an impact.
lift the car and look for more evidence of something hitting it
Old Dec 13, 2021 | 05:51 PM
Did you take your car to the Jiffy Lube monkeys to try and do an oil change?
Old Dec 13, 2021 | 05:52 PM
looks like there are two points of impact.
Old Dec 13, 2021 | 10:30 PM
pianos101's Avatar
unfortunately I don’t have access to one. Going to the body shop who did my work after the accident this week. Hard for me to say what the initial damage was and which damage was happening driving around hearing the grinding noise.
did you read my post? Last (and actually ALL) oil changes have been at the dealer.
Old Dec 14, 2021 | 09:42 AM
SpiderX1016's Avatar
Do you remember if the body shop or dealer had these type of in ground lifts? Usually when I see this is when backing up over these lifts or running over something on the road.
Old Dec 14, 2021 | 04:37 PM
pianos101's Avatar
Good question, i'll ask the body shop tomorrow. I don't remember going over a curb or berm.
Old Dec 15, 2021 | 07:07 PM
E92Vancouver's Avatar
I think you nailed the cause!
Old Dec 15, 2021 | 09:45 PM
pianos101's Avatar
i spoke to the body shop today and obviously they said it’s not possible. I don’t know how to prove it either way. Dealer said he can just get the metal and will install for free so I think I have to suck it up. Ugh.
Old Dec 19, 2021 | 09:24 AM
It is a cheap enough fix. Will be as good as new!
waynet_az
Aug 14, 2021 09:13 AM
lltfly
4G TL Problems & Fixes
Jan 16, 2018 09:12 AM
DanL07RL
Mar 8, 2017 08:23 PM
The Dark Knight
Mar 2, 2010 11:47 PM
car_lost
Nov 22, 2002 05:00 PM
