Lowbeam HIDs as DRL?
Like others, I don't like the halogen DRL on our cars. I'm thinking of running indepedent HID fogs, and pulling the DRL fuse.
Other option is to wire the current lowbeam HIDs so they are on all the time, and still have the 'Auto' lights work. Is this possible?
Thanks!!
Thanks!!
Sorry guys, I haven't picked up my car yet, not for a few days. So just doing some research now.
I thought with 'on', all lights will be on, sidemarkers, tail lights etc. I just wanted to have the lowbeams on all the time.
that would involve lots of fun rewiring and a new switch. its either all or nothing
simple. add a diode on each side so you can have 2 power sources for the lowbeams. add relay and switch for the power and control/
cost about 25 buck for parts. some labor will be involved.
I have not installed yet but I am making a seperate power source for the fogs so I can run them independent of ALL other lights.
Thanks!!
Thanks!!
Personally, I'd just put some LEDs in your DRLs.
When I had my 2G TL, I always drove with my HIDs on. I eventually had ballast/igniter problems. OEM replacement parts are expensive. It's not worth the wear and tear.
seems like a lot of work for basically nothing.
theyre just DRLs. i mean, you can replace the bulbs to make them look less yellow (or more yellow if thats your thing) but thats a lot of rewiring just to have your low beams and nothing else on when you can just have your lights on all the time and basicaly get the same results + parking lights.
thinking of just making my fogs DRL that are on all the time when the car is on day or night....but waiting on my 30W LED DRL bulbs to see how they work, I don't like losing the hibeams (as such on current 25w LEDs).
ya. i had the standard LED DRLs for a while but needed high beams once i moved to the country. replaced them with stock bulbs for now but i think i may go hyper yellow or arctic white like my fogs.
the stock DRLs are just soo dull. ick
The first thing I did when I got home from picking up new car from dealer was to pull the 7.5 amp fuse for DRL. No code and high beams work, auto feature works. You can add HID,s to high beams. Unless you live north of the boarder you dont need DRL. Some people are adding LEDs to their lights to match some of the new models out on market. As some have said above you will need to rewire to do that. JMO Good luck
