LED bulb replacements for DRL, brake light, turn signal, reverse
Hey all. i am wondering if anyone has replaced their incandescent bulbs with LED bulbs for their DRL, rear brake, turn signals, reverse lights? if so what brand did you end up going with? in the case of the turn signal, ones that dont hyperflash.
I'm using Philips LEDs (red 7443 and 168) for brake and tail lights, and AUXLIGHT amber 7440 with built-in resistors for rear turn signals (amber because I have JDM tail lights). Still using halogen reverse lights and DRLs for now.
cays0n (10-26-2023)
Thanks for the reply. i ended up getting the LASFITs for the rear brakes, turn signals, and the reverse lights. super bright. thinking about the DRL's in the front but will hold off for now. the front turn signals seem like a pain to change so ill probably leave them as is.
Morimoto 2STROKE 3.0 LED Bulbs for my DRL. It is the only LED bulb I know of that will work with the Honda/Acura low voltage Pulse Width Modulation system. It works at half brightness when in DRL mode and gives no error on the dash.
DESCRIPTION
Introducing the 2Stroke 3.0 LED Bulb – the pinnacle of innovation for your automotive lighting needs. Designed to revolutionize your driving experience, this cutting-edge bulb boasts superior beam quality, meticulously optimized for optimal output. With an industry-first adjustable base, it seamlessly adapts to various reflector and projector setups, ensuring unparalleled lighting precision at any angle. Equipped with advanced PCB technology, the 2Stroke 3.0 achieves remarkable beam accuracy with its uniquely designed LED chips and circulation cooling system. Unlike conventional bulbs, it defies weather challenges, actively maintaining its performance even in extreme conditions. The 2Stroke 3.0 also features a groundbreaking DRL Drive function, allowing compatibility with a wide range of vehicles. Upgrade to the 2Stroke 3.0 and enjoy unmatched clarity, adaptability, and longevity. Elevate your driving confidence – experience a new era in automotive illumination today.TECHNICAL SPECIFICATIONS
- Intensity: 2,600lm
- DRL Intensity: 780lm (30%)
- Power: 22w
- DRL Drive Voltage: 6-9V DC
- Material: Electroplated Aluminum
- Current: 0.25-0.79A @ 12V DC
- Light Source: Osram Oslon Black Flat S 5500K (Pure White)
kyzzyle (11-05-2023)
Krell101
3G MDX (2014-2020)
10-22-2013 05:49 PM
Logic717
09-11-2006 03:49 PM
