How often do you check MT fluid?
For those MT owners, how often do you check the transmission fluid? This car does not come with a dipstick and it is a pain to check the fluid according to the owner's manual. Any suggestion or recommendation will be appreciated. Thanks!
I am at 3 years and 50k miles, and I've never checked it. From what I remember without looking, its not something I can check easily. I believe it was something you checked by removing a bolt from the side of the transmission, but I could be wrong. Its been a while since I thought about it.
I've never heard of a car having a dipstick for a MT, though I've only owned a Nissan and Honda. Unless you see leaks, where is the fluid going that you need to check the level?
I havn't checked the maintenance interval chart for the TSX MT but I would suspect that a change is recommended between 30K and 60K. Assuming that the case was full when it left the factory you really shouldn't have to check it, unless a seal is leaking. Just change it at the recommended interval. If it's leaking then it's warranty time.
Im a mechanic at a honda dealer here in Salt Lake City Utah and at 30k the fluid still looks clean but it looses its ability to lubricate change it rebuilding a trans after the warranty is up is not cheap it will last easily to 60k on any fluid its the long term I worry about 100k plus
khoacu2 (08-01-2012)
I would assume that the change interval is something that the MM would indicate since it does so for the AT. The recommended interval for the 04 and 05 models (no MM, same transmission) is 120K miles or 6 years (for the first time, every 90K after that). I think this is too long (just my opinion), especially if a large percentage of the miles are not highway miles. I would half that, and probably stay on that schedule. Every 30K miles seems a waste to me of time, energy, and transmission fluid, but to each their own. I would probably check it once a year or so just because it would make me feel good. And after all, that's the reason we do much of what we do to our cars.
Thanks everyone for your reply. Sounds like I should not have to worry about checking the fluid level on a regular basis. BTW, my 09 Subaru WRX does have a dipstick for the MT.
it's a car-drive it
Yea i would not wait till 100 to do it i work at acura up north n i diff recom to do it at 30k or 60k it easy to change n i like to be safe n have a peice of mind that it clean i rather change it a lil early like the other member said once the tranny goes it gona be alot of money to fix it
as I previously wrote-I have all service done by acura/honda dealers. Seems to work for me. The way you drive also effects the life of the transmission. Never had to replace the manual transmission or clutch on the numerous vehicles I have owned. Almost 143K miles with the original brakes.
mada51589
05-03-2022 08:54 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
HeloDown
09-08-2015 06:51 PM
