hid kit in base model
Old Mar 13, 2012 | 04:43 AM
08r3308's Avatar
Hi All
i have a 2010 cu2 (tsx)
I have been thinking of upgrading stock headlights to either Philips crystal vision 4300k or hid kit.
Can a hid kit out of older generation fit? are they same?
Anyone with base that installed hid?
Old Mar 13, 2012 | 09:03 AM
TSXKid2010's Avatar
SEEYOU2CREW
Your car didn't come stock with it? Canadian TSX?
Old Mar 13, 2012 | 09:27 AM
a77's Avatar
a77
says Aus, Sydney - that's that down under place with the bridge and the funny white building. Evidently Australia spec euro accords don't always get the HIDs either.
Old Mar 17, 2012 | 08:59 PM
08r3308's Avatar
yes aus spec base
iw as looking in philips bulbs as well , not sure which way to go.
will philips give that blue effect in our headlights when they are turned off?
Old Mar 18, 2012 | 03:28 AM
I CU2's Avatar
Yes, base is actually a proper base spec here because the Accord isn't marketed as a luxury car.
The Euro luxury (comparable to your base)/Nav(Tech) models may have a few more perks then their TSX counterparts but there's not really that much besides the larger 18" rims, wood grain and washers.
Proper European market Accords have even greater features like safety distance computers and making sure you're not drifting off the road etc.
Originally Posted by 08r3308
yes aus spec base
Try OzHonda... only Canadian Base TSX's don't come with the HID kit.
Osram Night Breakers are probably the best halogens for range, not sure if you just want the bulbs to look white...
What blue effect are you talking about? The tinge that last in HID's for a few seconds when it warms up or the cut off colour gradient?
Old Mar 18, 2012 | 04:50 AM
08r3308's Avatar
i noticed especialy with blue philips parker lights (4000k) once switched off they give headlight inside that blue look , i don't want that , i just want white light better than yellow standard globes.
Old Mar 21, 2012 | 05:40 AM
chunsa's Avatar
For greater visibility I wouldn't get the "white" halogen globes. Stick to the more "yellow" bulbs for enhanced visibility. What's the point in getting globes for the look if you put yourself and other drivers at risk at night.
I normally buy the ones with increased night vision think it was osrams. They are far from white! I think most bulbs that give off that white look uses a blue cover.
Old Jan 7, 2013 | 06:48 AM
08r3308's Avatar
Anyway to fit stock d2s or even stock ballast but convert bulbs to h1.
Any help greatly appreciated
Old Jan 7, 2013 | 08:44 AM
ceb's Avatar
ceb
Might not be Sydney but still contains useful information and this
Old Jan 7, 2013 | 10:25 AM
opboarding's Avatar
Hello World
ceb you don't necessarily need to post your links that big. I know before they were hard to see since they were normal text, but a simple underline would do. Just looks kind of goofy you know?
Old Jan 7, 2013 | 10:34 AM
ceb's Avatar
ceb
Old Jan 8, 2013 | 06:24 PM
Yasser22's Avatar
How about getting the HID off a junked car?
Old Jan 13, 2013 | 05:05 PM
08r3308's Avatar
Original bulbs are d2s but in base h1 so unless I drill my housing which I will not do
Old Jan 14, 2013 | 12:44 AM
PyroDave's Avatar
get the full headlight off a junked car... without the HID projector, the HID will look like rice in a halogen housing
oyayjoe
Jan 1, 2019 10:17 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
MyBlackBeauty
Canada
Sep 14, 2015 05:28 PM
oyayjoe
Sep 12, 2015 04:40 PM
EE4Life
Sep 11, 2015 10:13 PM
