Hid
Hid
Hey guys. Finally got the tsx 3 days ago and Im trying to get hid fog and signal light to match oem head light. Im not sure stock lights bulbs 4300k?? And also what type of bulb do i need if i want to replace lights that r on during the day where high beams r.. ( low beam) couldnt turn it off during the day.. Just hate that yellow look same as signal light..
Thanks guys!
Thanks guys!
The lights that are on during the day in the hi beam assembly are the DRL (daytime running lights). You can change the bulb but the only way you can get rid of the yellowish light is to replace the bulb with an LED bulb but that'll flash your DRL light on the dash unless you get a resistor for it. The LED bulb is the only way to get a clear white color in that area. And yea there's threads which answer all your questions...definitely use the search for your next questions.
