heated seats not working after radio replacement 09 TSX
Old 02-06-2017, 09:53 AM
4th Gear
antont17's Avatar
Hi All!
I recently replaced my radio on a non nav 09 tsx - after the replacement I noticed that my heated seats aren't working as in the light on the switch does not turn on at all.
I tried looking at the fuse box diagrams and search the forum to no avail. Does anyone know which fuse is for the heated seats? any other suggestions?
Thanks in advance
Old 02-06-2017, 10:11 AM
Received 16,266 Likes on 11,974 Posts
replacing the radio involved taking out the dash/console??
if so, check your work. you might have disconnected something by accident.
also, the light or bulb might have gone out.
Old 02-06-2017, 10:20 AM
Received 8,711 Likes on 6,718 Posts
you probably forgot to plug the switch back in
Old 02-06-2017, 12:39 PM
4th Gear
antont17's Avatar
I didnt have to unplug any of the heated seat controls as they arent in the way , i guess there is a chance that the plugs came loose. Ill double check. I wanted to check the fuses firat just in case because its the easiest thing to troubleshoot first. I still dont know which fuse contols the heated seats
Old 02-06-2017, 12:41 PM
IIRC. The owners manual has the fuse panel chart no?
Old 02-06-2017, 12:42 PM
you can also LOOK at all the fuses...replace the one that's broken.
Old 02-06-2017, 12:46 PM
4th Gear
antont17's Avatar
The owners manual has the same table that is printed under the fuse box. Acura really did make sure that they are as vague as possible. When it comes to that schematic
Old 02-06-2017, 12:52 PM
You don't see a fuse that says H/Seat??
Old 02-06-2017, 03:46 PM
4th Gear
antont17's Avatar
No.
Old 02-07-2017, 09:00 AM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Old 02-12-2017, 09:00 PM
Touchaclass's Avatar
Check the connection at the heated seat switch... You do have to remove that to change radio. That whole section comes out and it allows you access to 2 screws underneath your pocket or navigation unit. Then after you remove that you can get to radio. Nevertheless, you can check that in 5 min on way to work. Open cup holder door and pull up on the underside of door. That will Unclip the bottom section so you can pop out section with heated seat switch.
