Gracenote Update for Acura TSX 2011-2012 Tech
The Jan 2012 Gracenote update is now available...
http://www.navteq.com/gracenote/acura/tsx.htm
Gracenote® is a music database that enables your Acura audio system to identify artist, album and song names. The most popular and trusted ID technology for consumer electronics today, Gracenote® will help you better manage and thoroughly enjoy your music collection.
Updates to the Gracenote® database are released quarterly and can be downloaded for installation on your vehicle's audio system. The updates for your 2011-12 Acura TSX must be obtained from this Web site as files from other sources will not work.
Current Vehicles Supported:
2011-2012 Acura TSX, 2011-2012 Acura TSX Wagon
If you own a TL, MDX, RDX, or ZDX, return to Choose a Vehicle and select your model.
Version Number: 4449
Database Date: Q4 2011
The following 5 users liked this post by FromG35toTSX:
benben01 (02-04-2012),
Ken1997TL (02-04-2012),
mkeefe (02-06-2012),
MrOtocinclus (05-12-2012),
oblio98 (02-04-2012)
Received 2,329 Likes
Thanks, updating it this morning
To my knowledge it is only used for files on the HDD. When a CD is copied to the HDD it uses the Gracenote database to identify the title/artist/tracks of the CD so if the CD is not in the Gracenote database version currently installed on your HDD you will get generic title information. Once you install the new version of Gracenote database you can go back and try to identify previously unidentified CDs.
Developer & Car Fan
Gracenote is used to identify CDs you put in the car. Most newer and older CDs have track information which can be used to rip the disk to the HDD (If applicable).
Matt
Matt
Note: just updated to latest Gracenote DB. Main file is about 350MB, which on a PC would take less than a minute; to update it in the car, either CD or USB stick, takes about 10 minutes. My first time doing this, didn't want to idle the car for 10 minutes, didn't want to sweat into the seats for 10 minutes.... kind of alternated, with turning engine and accessory mode off and on, and it still worked, fortunately.
There should be clearer info re: whether you should be running the engine or not while updating, and how long it will take.
My advice: put it on a USB stick (next one will be released July/August 2012) and update it when you are planning to be driving for at least 30 minutes. Start it before you take off, though.
Evil Teo
3G MDX (2014-2020)
14
08-16-2020 04:29 AM
divac
08-29-2018 10:13 AM
