Factory vs Yakima/Thule/Etc crossbars for SportWagon
Hi forum -
I've been rocking a trailer-hitch mounted bike/ski rack for years now (continued use on my 2012 tech wagon with a Curt hitch) and have been just fine doing so. Recent outdoorsy activity has necessitated the planned purchase of a roof box of sorts, which means I need to find crossbars.
I'd long considered the Acura-branded crossbars (part number 08L02-TL7-200) since they're designed to work with the car's rack system and since they're comparatively cheaper than other options.
I don't want to just buy them because they're cheap - has anyone else used the Acura crossbars? Any preference for those or any other brand such as Thule, Yakima, Rola, Whisperbar, RhinoRack, etc? Staying under $400 would be ideal, but isn't mandatory.
As for boxes, I've considered the Yakima SkyBox 21 or Thule Sonic XXL. Anyone have experience with either?
Thanks!
Thanks!
I have the Thule 21 cubic feet box
I use oem cross bars
Nice! 21 CF box fits well? Do you have it in contact with the antenna at the back? How far forward does it come over the sunroof/windshield?
Onto the cross bars - how much noise does it produce? I had been considering the Thule AeroBlades due to their purported low noise. Do you keep them on the car all the time or only when you're hauling things?
I only install to haul
Otherwise there is noise
I don't have a front fairing
No issues with rear antennae or opening hatch as I mount our box forward
I can also open sunroof with box no issues
I have the Yakima Whispbars on my car. Sits flush up against the factory rails. I use it for bike rails and yakima cargo box.
Roof Rack Rail Bars | Whispbar
We have Yakima on the Waggie and use the 44" fairing.
https://www.yakima.com/44-fairing
I set it just back of the moon roof and noise it pretty minimal. Also gas mileage doesn't drop that much either.
Basically goes on it spring and comes off just before winter so as to not interfere with snow removal.
Techno... I never like the look of those too tall/too wide crossbars. (sometimes needed because many Thule/Yakima attachments only fit their bars) I discovered after buying the TSX ..my wife's V70 Volvo had the same runners! I had gotten her Volvo crossbars off Ebay because I carry boards atop all our cars.
It turns out not only Volvo ..but I see the same contractor's runners on VW's Passat wagon and recently on a Nisan Rogue. (did not see crossbars on either)
I had to do a bit of trimming with a chopsaw to narrow the rear crossbar to fit, but I am very happy with the results. ..and have a great little surf wagon.
Jim
Jim
I use it for carrying bikes and have a set of rails for a fork mount.
Jim
Jim
I found a set of AeroBlades (the kind that sits atop the runners) with the mounting brackets for $250 on Craigslist, debating if I should just get those and pat myself on the back for finding a good deal.
t-1 ...they appear to be Volvo P/N 30779107 ..her's is a 2008. Also google 'volvo load retainer' ...I'm pretty sure I saw a set for $144 ..but mostly ~$200. Again, the downside: you have to mod these to fit. I have the tools and am not afraid to f-them-up in an attempt to get the look I like.
Jim
Jim
cu2wagon (05-22-2016)
Received 7,772 Likes
Jim
Jim
Just looking at the pictures, it almost look like they both have the same designed roof rails. If they're both in your driveway, can you confirm or deny?
(It at least appears that they're similar enough that the crossbars are compatible as you mention)
Claro CU.. How'zs?
We got her '08 wagon a few years ago, about 2010. For some strange reason a Volvo dealer in PA had four of these wagons with titles marked 'Rental' with ~18k mileage ...but they were not able to offer conventional financing locally? So I got a $40k wagon for like $22. Took their word on condition, had a transporter bring it. (had to fly to Columbus OH for the TSX) ...somehow the Volvo even ended up 'certified' ..but never really need an extended warranty. Volvo is a good car ..much more like your father's Buick tho'.
Like buying a Red car - once you start looking, you will see these rails everywhere. Some Chevy and Caddy SUVs use them also.
Jim
Jim
Claro, si. Bueno!
Very interesting. I like the low profile of the rails; I might need to track down a set.
So did you just need to chop the actual extruded cross bar to fit the TSX? Looks pretty straight forward.
I love spreadsheets.
I have the Thule Aeroblade cross bars on my sedan with the Thule bike rack and kayak carrier. It does the job well and it doesn't look too bad. It's also pretty easy to install and remove when needed. The only issue I have is the elevated wind noise when driving at highway speeds, but that issue is only noticeable when the sunroof cover is open.
on the car.
on the car.
Lucky us Denali... we have the rails and room with the seat down. The good news about Thule and Yakima is that there are plenty of 'sport specific' grips. Your Yak looks good up there. ..flip it over, it looks similar to the window profile.
cu2, Chop saw. I didn't save the pic, but I sorta remember that I took off 1.5" off the extrusion. (may a little tight but better than too loose) Goes back together pretty easy. I'd still scan Ebay for other OEMs that use the same contractor; GM, Datsun (Volvo) ..even more, likely.
Jim
Jim
Jim
Jim
Does anyone know if the OEM rack is just a Yakima or have a closeup of the attachment to the rails? I'm going back and forth between the overpriced options of OEM, Whispbar, and Yakima Ridgeline w/ Aerobars setup. Racks have always cost too much, but these 3 are all nice and close in price (Labor Day sale at REI vs Bernardis). The Whispbar seems sleeker and more OEM than OEM, the Yakima a little clunky.
well, I got the Whispbar, which is really nice and easy to install, but have to get adaptors to attach my existing Yakima bike rack, and they don't seem to evin exist yet for my ski rack, which is also by Yakima. That black stripe is a T shaped channel under rubber that apparently is the same as on a Thule, and they may have an adaptor I can use. I probably shouldda just gotten a chunky roundbar....
I use this with two Yakima bike rails (fork mount). I'm thinking about ski racks... perhaps the short version that holds 4 pairs of skis instead of 6. But for now, we don't ski that much, so skis and boots just go in the trunk with one seat folded down.
I know this thread is a bit dated but I still think it's better to keep all this in one place. I'm looking for some crossbars for my 2014 Sportwagon to mostly haul lumber, a few 2x4 or a sheet of plywood. I suppose most of the brands mentioned here will do the job well enough. Prices I'm seeing are $300 and up. Maybe I'm shopping in the wrong places.
That said, $300 sounds about right. Maybe you can find some used ones from someone here, or on eBay.
I've been low-key looking for crossbars and haven't stumbled upon any yet.
I'm really liking the Whispbars and will likely go that route. Since this tread bubbled up last night I went and looked again. For the SportWagon, we need the Whispbars S54 and I found them for ~$250 at Amazon. Last night they had one listed in their Warehouse Deals for $217 but said it was missing mounting hardware. But, there really isn't any mounting hardware involved so it might be a worthwhile gamble.
fbt: I was looking for some inexpensive bars to accompany a paddleboard on a plane to the Dominican. I didn't want to use soft racks on a rental CUV with a larger/heavier board vs the typical surfboard. 'Never made the trip, but I got some really decent bars off Amazon. 'Cargoloc' for ~ $40. I don't like the 'hanging-over-the-side' look for my personal car, but if you're only using it occasionally –especially for 4x8 ply, etc.— why spend a lot of money? Cheers.
Jim
(I'm with McCoy ..I got a ping that the thread was opened again. Why not?)
Jim
fbt (05-07-2017)
Just a thought... if you don't like them hanging over the side, is there anything to prevent you from hack-sawing off the excess and putting the end cap back on? Looks like they are just aluminum channel.
I found something that looks interesting last night. Well, actually the eBay "do you like?" algorithm finally came through... Usually it's stupid and recommends "oh, you searched for TSX stuff, would you be interested in a carburetor for a small block Chevy?" but this time, it accidentally had something useful.
It appears, to me, that the Whispbar generic MIC specials are out there... For like 20% of the price!
Check it out:
Pair 93-99cm Aluminum Top Rail Roof Rack Car Cross Bars Crossbar Kayak Carrier | eBay
I need to take a quick measurement, but I think one of the sizes they have listed will work. And I need to figure out what the right keywords are to find these because I'd be there are others once we figure out how to find them.
No-Name eBay:
Whispbar:
Check it out:
No-Name eBay:
Whispbar:
I pulled on the end cap and it feels like it could come off. For my uses I don't care what it looks like.
Placed an order for the Acura OEM 08L02-TL7-200 rack for my 2013 tsx wagon for a price I couldn't refuse. Before I get it next week before I use it I don't have a chance to return the rack. Looking for words of wisdom about the OEM rack or close up pictures. Does it produce a lot of wind noise?
I'll be using the rack to haul a wind surfing board or a paddle board or kayak short distances.
Recently purchased this like new condition white unicorn wagon.. has 26,000 miles on it. Even has a technology package. Lovin it!
