Dust and Pollen Filter?
Does anyone know how to replace this kind of air filter?
User Manual does mention about it but nowhere indicates how to replace it or at least where it is.
Of course they don't want you to do it, I'm sure the dealer has a huge mark-up on the installation and replacement.
Yes, I was surprised that this was missing from the manual, yet oil change was not. It's amazingly easy to change, too. Just remove the tray for the manual (if you have it installed), squeeze the clips on both sides, pull out the cover, then pull out the filter assembly.
Yeah, not sure why they show the oil change, but not other common changes people do like the cabin air filter. I guess a lot of people change their own oil, so they felt they needed to have more detail in the manual.
One thing I've found as well, is that changing your own transmission fluid (not flush) is even easier on some cars than changing your own oil. On my previous 2006 Civic it was butt easy.
Thanks m8
It is in the glove box and is extremely easy to replace on your own. You need to remove the little shelf in there to access the door in the back wall of the glove box but you can see it pretty clearly back there. Takes 1 min or so to do the swap.
Just a FYI Walmart now carries cabin air filters and they have Arm and Hammer baking soda in them. Something like fresh air is the name. For 18.00 compared to like 39 or so at the stealership.
rcs86
08-02-2016 06:52 PM
AcuraKidd
09-25-2015 11:18 PM
