DRL...who's running what LED in there?
Seems many LED's note that they shouldn't be used as a DRL due to lower Volts
Thanks in advance.
I like these in my 05 TL fogs!!
Products-Gt lighting USA is hid and led offroad lighting system wholesaler in Arizona US.
Thanks in advance.
i have the ijdmtoy LED kit in mine.
High beams are basically nonexistent. Nice bright white DRL though. Beats the stock bulbs. Attempting to turn on the high beams dims my fogs if theyre on at the same time.
The LEDs you have from gtlightingusa in your 05 fogs are BRIGHT and perfect for DRL/high beam.
I run them for my DRL, and at night it is bright, like high beams.
I should note that no, i don't drive at night with DRLs, i was only seeing how it looked.
You just need to buy a harness from ijdmtoy for it to work.
Any "tower" LED you buy for DRL will be dim, such as the tower LEDs that come in the ijdmtoy kit.
That's why I opted to buy just the harness from iJDMToy and the Cree LED bulbs from gtlightingusa.
so these:
9005 9006 H7 H11 Plug-N-Play Error Free Decoder Wiring Kit For LED Bulbs
and the 9005 LED from gtlighting and im all set?!
I will have DRL and also bright light function
or just Bright all the time?
Graphite Ghost
i would buy the leds where you get the best warranty. buy the brightest ones they make for 9005. that are in your budget.
yes you will have both. i was commenting on the 'NO USABLE high beam post'.
and yes those resistors work. and are pnp. just put them somewhere not touching any other wires or plastic as they get super hot.
so it seems v led's has something maybe different?
9005 PLUG N' PLAY DRL DAYTIME RUNNING LIGHT MODULE | 1 EACH
These seems to supply 14.5v to the led no matter? So then the DRL would be very bright at all time. DRL mode full power & Bright mode full power
Does the one from ijdm, just solve the error code issue, So allow lower volts during DRL mode(dimmer) and higher volts at Bright light use?
what about these off ebay?
http://www.ebay.com/itm/9005-Load-Resistor-50W-Error-Free-Canbus-Adapter-Fog-Light-DRL-Daytime-running-/360913127141?pt=Motors_Car_Truck_Parts_Accessories&hash=item54081946e5&vxp=mtr
i see some are 50w 8ohm and others are 50w 6ohm? work the same as ijdm??
Thanks,
Thanks,
Graphite Ghost
For the resistors i used TWO of these
9005 6OHM 50W IN-LINE LOAD RESISTORS + MOUNTING PLATES | 1 PAIR - DRL/Fog Light Resistors - Resistors
but you could use one of these ^^^^^^ and one of these
ACURA TL DRL DRIVER SIDE IN-LINE 25 OHM 25W LOAD RESISTOR WITH MOUNTING PLATES 9005 | 1 EA - DRL/Fog Light Resistors - Resistors
the second one wont get as hot.
then for the leds get ones with the best warranty that you can afford.
farking vleds wants 200 for the 3000 lumen. but they will garantee them for a year.
gt lighting seems like the shizz.
and get anyone's resistors that match those specs......one is 6ohm 50w the other is 25ohm 25w
vleds and others do add the ends so its all PnP if that matters.
you dont need that drl box from vled.
I'll break it down for you.
You need to buy two things:
Acura Honda Lexus High Beam LED Daytime Running Lights Decoder Modules
Option R2.
And:
9005
Option R2.
And:
9005
Option R2.
And:
9005
Option R2.
And:
9005
does this get you DRL (low) and High Beams?
DRL gets supplied 6V power, so it's dim.
That's why if you throw your CURRENT DRL halogen bulb into a socket that's 12V or when you switch to high beam (12V), it'll be much brighter.
What the harness does, is two things.
It supplies your DRL FULL power. Makes that 6V into 12V.
It also cancels out the error on your dash.
If you think about it, that means your DRL will be the SAME brightness as your high beams, because both applications are supplied 12V power.
Why do you want FULL power for your DRL?
LEDs can be difficult to see in direct sunlight.
Plus, who doesn't want to have bright DRL lol
Just don't be an idiot and drive with DRL on at night.
saxonfan (09-11-2022)
guitarplayer16 (12-09-2014)
You lost me...
You said prior that you have a low beam (DRL) 6v or whatever and then a high power Bright beam(12v+) with the decoder...
SO the link just supplies 12V at all time so the DRL is the same brightness as the High beam?
And run DRL at night? Doesn't the DRL go off when headlights go on? The when you flip bright switch they come on at full 12v?
Maybe I got too technical, but that's what you asked for when I already told you what to buy but you insist to learn more lol
Understand how the stock lighting is![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
DRL - 6V
High beam - 12V
What the harness R3 does is makes the DRL 12V.
Same brightness as high beams![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
And yes the DRL turns off when you switch on low beams, it was just a side note not to drive with DRL at night, even though I know you don't lol
DRL - 6V
High beam - 12V
lol...yeah txt is tough to follow.
I want the DRL for daytime at 6v or so I assume. Or is the LED just to dim at that level?
Then I want to have High beam function (12V) when I need brights!!
In short:
Trying to basically accomplish what the factory halogen bulb does but with LED and no error messages if that makes sense.
In short:
In short:
In short:
If you want full brightness DRL, get option R3.
Is there a noticeable difference in brightness? hells yeah.
Most LED DRL bulbs running at 6V you won't be able to tell are on in sunlight.
The gtlightingusa bulbs are probably bright running at 6V, i don't know.
Keep in mind the Option R2 is meant for your TSX.
Option R3 is meant for the 3G TL, because bi-xenons.
Will your car blow up using R3? No. Technically the R3 harness will work on your car too because all it is doing is using a relay to deliver 12V from the battery to the bulbs.
I don't know why they don't list option r3 for your application.
blownby (12-10-2014)
rockyboy
12-06-2022 02:29 PM
09-17-2015 09:01 PM
