Driver Courtesy Lights not working
hi guys
ive got an issue thats been bugging me for a while, ive searched up on this issue and couldnt find much on it
my courtesy lights (small lights on every door) on every door except passenger front have all gone kaput. Ive checked the fuses and all seem to be ok. Replaced the bulbs and no change.
any one else have had this problem?
this is a part of the driver door light led not working issue, its been discussed on here.
i did have all my lights go out EXCEPT for the passenger door light while i was installing led's and it turned out to be the fuse in the engine bay fuse box.
on my car though not only were the door lights out but also my dome lights and key light.
if ONLY your door lights went out then it's probably the bulb sockets that shorted out on each one. how it happened?? who knows..unless you were putting in led's. if so or even not, put all stock bulbs in and take it to dealer.
thanks for the reply
i will check as soon as i get home for fuses even though i checked before... ill double check this time.. i did end up putting in leds in the drivers courtesy door, so i must have shorted them out.
do you know what fuse it was roughly?
coincidently my dome lights key lights etc have gone out as well. they must be on the same circuit? what did you do to rectify it?
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
