Double-lock
Double-lock
Hi,
do you know, how to programe the car to turn-off that double-unlock function? If I press unlock button on the key, only driver's doors unlocks, but I want to unlock the whole car at once...
Just did mine this morning..one button, all unlock..it's annoying hitting it twice.
Do you have two sets of keys? Look in the back, one should say Driver 1 and the other Driver 2. You need to link the remote transmitter to the system before customization is allowed.
Try to save the driver seat position by hitting the set button and then 1 on the door panel, the light should blink once the memory is set. Then move the seat forward or backward and get out of the car and lock it. Unlock the door with your remote, when you open the door, the seat should move to the preset memory position and you should see Driver 1 on the MID. Once the system recognize a driver's remote (You will see Driver 1 on the MID), go to CHG SETTING, ENTRY and change the locking settings. To reset the remote to default (unlink or link) just press both lock and unlock button at the same time.
Here's the personalized settings intruction video from Acura:
For door locking:
http://owners.acura.com/Model/Featur...delid=CU2E6AKW
As mentioned above, you need to link the keyless fob to the system first before you can do customization/personalized settings on the MID.
Linking to the Remote Transmitters Keyless Entry with Remote Transmitter with Driver Position Memory System.
Remote transmitter 1 and 2 settings are stored separately. To link or unlink the remote transmitter, press and hold the Lock and Unlock buttons simultaneously until the LED blinks once (linked) or twice (unlinked).
For door locking:
You may be out of luck with your European model.
Check and see if there's door lock/unlock option under CHG SETTING on the MID.
The double click unlock is the factory default setting and it's to prevent someone from jumping into the passenger door while you unlock your car door. Good Luck.
09TSXTech, I tried your first tip with the seats, and that didn't work. Tomorrow I will try pressing the both buttons. Should I press them after unlocking or before?
BTW, my both keys are exactly the same, no driver 1/2 marks on them
if possible you can take a pic of your gauge cluster?
sadly it didn't work My keys are really exactly the same.
I had to order the Owners Manual for Euro, they charged me nearly 100 bucks and I have to wait 6 weeks for delivery.
Do you have memory seats as the keys Driver 1 and 2 are for the memory seats? If you do not have that feature, you might be missing some personalization features like the double-lock option.
I think you have to hit the lock/unlock button at the same time and then push the memory number on the door that you want associated with that key fob.
once I reach door unlock option, which option should i select for one click unlock all doors. there are five options under door unlock mode.
1. Driver door with shift to P
2. All doors with shift to P
3. Driver door with IGN Off
4. All doors with IGN Off
5. Off.
I did not see any option related to remote transmitter by one click to unlock all doors.
5. Off.
Could you please send me the pdf file on the 2010 TSX manual?
itristan1@stx.rr.com
thanks and is this country great or what
Sonny
Sonny
Sonny
Sonny
https://techinfo.honda.com/rjanisis/...BTL12010OM.pdf
This is an easy thing to do. You might want to read your owner's manual. I configured the auto unlock on mine because I wanted the car to unlock all doors instead of unlocking just the driver's door when you shift to Park. There is also a setting for the one you are looking for. Its very simple. Once you linked your keyfob with your car then you can access the configuration settings by pressing the up & down info button on your steering wheel then just follow the choices and change it to your personalized settings.
aznbo187
11-09-2010 06:47 AM
