DIY Oil Change
Old 08-02-2011, 06:42 PM
5thTo2nd's Avatar
DIY Oil Change
I thought I'd put together a little DIY of the most simple of maintenance procedures since there isn't one so far for the 2nd gen. Personally I like doing as much as possible on my own. It saves money (more money for mods!), is almost just as fast if not faster than going to the dealer and makes you appreciate your ride more.
That said, things can still go wrong like a jack failing, over-filling the oil, etc so if you don't feel comfortable doing this yourself then get a shop to do this.
Tools Needed:
  • Wheel Chocks (or something to block the wheels with)
  • Jack and jack stands
  • Oil catch can
  • Oil filter wrench (I don't have one but admittedly it'd be much easier with one)
  • 10mm and 17mm wrench
  • New crushable washer (usually free from the dealer when you buy the OEM filter)
  • New oil filter
  • 4 litres of 5w20 (I switched to Synthetic on this change)
  • Funnel
  • Lots of rags to mop up old or spilled oil
  • Ziplock bag for old filter
Remember to dispose of your used oil at a proper dumping facility. Some shops also take old oil.
Here is the MID indicating that an oil and filter change is due:
Gather all your gear together:
Set the parking brake and jack up the car on a hard, level surface (concrete preferred, asphalt is too soft). Block the wheels that are still on the ground. Set your jack stands at the appropriate jack points and get under the vehicle and locate the under cover that we're going to remove. Grab your 10mm socket and remove these 3 bolts closer to the passenger side of the vehicle:
And these 4 bolts closer to the driver's side:
Remove the undercover and set it aside:
Pop your hood and remove the oil cap. Go back under the car and locate the oil filter and drain plug (there's an arrow pointing to the drain plug and it even says Engine Oil so you can't mess this part up):
Closeup:
Those damn grease monkeys at the dealership always over-tighten both the filter and the drain plug--that's another reason I like doing this myself.
Remove the drain plug and filter and let it pee into the oil catch pan:
Honestly I don't know how those 30min oil change places do it...I let mine drip for at least 15-20 min to get all the old crud out.
While you're waiting you might as well do something productive. Some people like to clean out their air filter or something like that. I take this time to prime my new oil filter by filling it with clean oil and clean up my oil drain bolt and make sure that I replace the old crushable washer with a new one. Take a little fresh oil and grease up the new gasket around the oil filter.
Place the old filter into a ziplock bag and empty the old oil into a suitable container (I use old oil jugs).
Go back under the vehicle and re-install the oil drain plug (with crushable washer) and filter. Make sure the old filter gasket came off with the old filter. Tighten the drain plug to 29 ft lbs. Hand-tighten the oil filter.
Grab your funnel and fill the engine with 4 litres your favorite brand of 5w20. Check the dipstick after you've let the oil settle and then replace the oil cap.
Go back under the car and re-install the undercover. Make sure to have the front of the cover go into this slot. You'll know what I'm talking about when you see it.
Remove the jack stands and lower the vehicle. Get into the car and start it up. As per the owner's manual, if the oil pressure light does not go off in 5 seconds then turn off the car and check your work. I like to let it idle for a few minutes then check for leaks and re-check the oil level. I also take it for a quick spin and re-check the level. Hold down the reset button on the steering wheel and reset the MID and you're done.
Congrats that's it! This was my first time doing an oil change on this car so it took a bit longer (90 min) but it should only take 45 min or so once you're used to it.
The following 25 users liked this post by 5thTo2nd:
Acura_Dude (09-08-2011), atlacura (08-06-2015), BaoZZeR (11-29-2012), ed_423 (08-03-2011), EL19 (08-27-2012), Fenji (08-20-2013), FlipRizzi (03-30-2012), gwickes (04-21-2012), Harper (09-14-2011), hcp (03-30-2012), live2hit01 (08-03-2011), loner (08-03-2011), Mercedes>BMW (11-07-2012), MrOtocinclus (08-03-2011), MrTee12 (09-17-2012), opboarding (03-31-2012), philarious (11-19-2013), Puppetmaster (09-20-2012), robpp (03-30-2012), rotciveel (10-22-2015), rx2010 (03-30-2012), Supreme (08-04-2011), Terdbath (08-03-2011), The Stig CA (01-06-2013), xtcnrice (09-03-2014) and 20 others liked this post. (Show less...)
Old 08-02-2011, 10:49 PM
You see me, I CU2
Mr. NC's Avatar
This needs sticky status
Nicely done bro! Always wanted to do it myself now I know how
Old 08-02-2011, 11:03 PM
Op is too busy to care
KillerG's Avatar
Sticky and rep for this awesome DIY pls. These always go under appreciated.
Old 08-02-2011, 11:46 PM
09TSXTech's Avatar
Thank you 5thTo2nd for the excellent write up.
Old 08-03-2011, 12:21 AM
ShawnAmin
shawnamin's Avatar
perfect timing, service b1 light just turned on for me.
Old 08-03-2011, 12:57 AM
PyroDave's Avatar
shawn keep in mind that b1 includes some other service beside oil change. tire rotation, along with a more detailed check of stuff like brakes
Old 08-03-2011, 03:09 AM
SeeYou2Crew #2
ed_423's Avatar
great write up! i might just try this when i get the tools needed!
Old 08-03-2011, 03:27 AM
npathak's Avatar
Awesome write up! Might do it when the Oil life goes down more. i think im at 50%
Old 08-03-2011, 06:38 AM
its rayden's Avatar
i would start the car and check for leaks before reinstalling the undercover and lowering the car
Old 08-03-2011, 07:00 AM
5thTo2nd's Avatar
Yeah it's not hard at all. Actually, it's probably the easiest car I've ever done since the location of the filter is so convenient. Some cars have the filters in the crappiest places.
For B1 you can rotate your own tires too if they're not directional. Rotation pattern is in the manual. Even if they're directional, you can move front-to-back for the time being and then do a proper rotation later. Brakes can be eye-balled.
Yeah, definitely check for leaks before the cover is back on LOL! I'm just used to starting up the car last cause my previous cars were all stick and I had to lower the car before getting in and depressing the clutch.
Old 08-04-2011, 02:11 PM
pinatubo's Avatar
@OP, I give you 10 for the in-detail instructions and I give you an additional plus (+) for this statement: Take a little fresh oil and grease up the new gasket around the oil filter.
As I read through your instructions, I wait for a chance to knock off some points on particular trick but obviously, you are good
Not whole lot of people who diy knows this little trick.
Another trick is instead of dispose the crushable washer, you can just flip it and reuse one more time but who care since it's dirt cheap and often comes with when you purchase the genuine Honda oil-filter.
Thumbs up for you.
Old 08-04-2011, 07:20 PM
5thTo2nd's Avatar
Thumbs up for you.
Hey thanks. I used to take close to 2 hrs cause I like to check and recheck things and I'm kinda anal about anything car-related LOL
Nice trick on the crushable washer! Another thing some people do to save some coin is to change the oil filter every other oil change. I've always changed everything cause I figure it's just a few bucks more.
Old 08-05-2011, 08:33 PM
the_razor's Avatar
what you guys think of the Mobil 1 Extended Performance
does our TSX need that or stick with the regular Mobil 1
Old 08-05-2011, 10:55 PM
No1nfoProvided's Avatar
Correct me if I'm wrong, but I thought our cars need more than 4 quarts of oil. I think the manual says 4.4 quarts. People in the 1st gen forum say theirs takes as much as 5 quarts.
Old 08-06-2011, 02:59 PM
5thTo2nd's Avatar
I remember there was an old thread about how good Mobil One EP was for our car...it might have been written by heavyduty? Anyways, try searching for it cause I'm pretty sure it's on here somewhere. I think he said it made a pretty noticeable difference.
Yeah I was pretty surprised too at how little the oil change capacity is. I just double-checked the owner's manual and it says 4.2 US quarts, or 4.0 litres. That just means we don't need to buy as much oil.
Old 08-07-2011, 01:42 AM
OH MAN. I just noticed you put 4L. That was my bad. I was thinking 4 quarts (I'm from the US), so I thought you didn't have enough quarts in there. It's pretty annoying because I've had half a quart of Mobil1 from my previous oil change almost a year ago. Is that leftover oil still good to use for my next oil change, or should I just dispose of it?
Old 08-07-2011, 03:06 AM
09TSXTech's Avatar
^We Canadian are used to Metric and SAE measurements, heck, we have both English and French as Official Languages.
But to our American members:
1 Quart = 0.946352946 Liters. So 4 litres = 4.226753 Quart
Old 08-07-2011, 11:10 AM
Haha. I wish the US switched over to the metric system like the rest of the world. I shoulda known better, tbh. I work in a lab and all of our measurements are in liters and stuff. I don't understand why the US has to do things differently, like drive on the right side of the road and whatnot.
Old 08-07-2011, 11:38 AM
5thTo2nd's Avatar
Yeah, metric is the stuff. But for temps I prefer the US way of Fahrenheit vs Celcius.
You should have no problem using old oil (after all it was in the ground for thousands of years anyways right). The only thing I know of to use fresh is brake fluid since old bottles can absorb moisture which can affect braking effectiveness.
Old 08-29-2011, 10:33 PM
MyBabysBaby's Avatar
I had my oil changed today by the dealer. I went there because when I priced the oil, I would've spent more on the oil than I would have at the dealer, not to mention the time. Turns out, they didn't charge me for the service.
Quick question, my MID only showed "B", not B and a number. Is that normal?
Old 08-30-2011, 12:00 AM
09TSXTech's Avatar
Good for you, a few forum members managed to get a coupon for B service.
As for the number, it doesn't show up every time. 1 just mean tire rotation, 2 means air and cabin filter change, 3-transmission fluid change and 4 means spark plugs and timing belt. Just check/refer with your owner's manual.
MyBabysBaby (09-01-2011)
Old 09-06-2011, 05:53 PM
itr_1211's Avatar
Sorry for the very OT question, but would anyone happen to have the part #s for those 7 bolts holding the cover on this pic? TIA
Old 09-06-2011, 08:03 PM
5thTo2nd's Avatar
90143-TL0-000 Lower Cover Bolt. Should be like $2 at your dealership.
If you ever need to find out part numbers look up Honda's e-store:
http://estore.honda.com/acura/parts/...-4-tsx-5at&dl=
Old 09-06-2011, 08:08 PM
s40 driver's Avatar
Great write-up! Hoping all is well, I've been busy with school and Jeep Wrangler shopping . I've two more free oil changes from the stealership before I start doing my own changes on the TSX!
Old 09-07-2011, 07:50 PM
5thTo2nd's Avatar
thanks! Hope you're enjoying your Type S kit as much as I am. Who's the Jeep going to?
Two free oil changes takes you pretty far...you probably won't be DIY'ing till mid next year!
Old 09-07-2011, 09:51 PM
09TSXTech's Avatar
^ They don't give free oil change here in BC.
5thTo2nd, maybe you should get a SE badge on yours.
Old 09-07-2011, 10:00 PM
Gonzilla's Avatar
Great post! Any person can read this and not mess this up!
Old 09-08-2011, 07:13 AM
Карты убийцы
Professor's Avatar
I'm too lazy... I get a coupon every two months from the dealer for a $29.95 oil change and car wash.
nj2pa2nc (09-08-2011)
Old 09-08-2011, 05:41 PM
s40 driver's Avatar
I enjoy the kit very much, I always get complements from other TSX drivers. I suppose it could lose a bit of its luster once some of these 2012 SE models hit the streets... but we had the kit first
I am replacing my '08 Ranger with the Wrangler and my better half will be using it as a primary vehicle. I am going to pick the Jeep up on Saturday and looking forward to it!
Yeah, I've had my TSX for a little over a year and should be due for the second oil change within the next month or two. I'll be well prepared from this write up if I end up having to do changes myself sooner though. Thanks again!
Old 03-30-2012, 01:27 PM
PyroDave's Avatar
i'll be changing my oil tomorrow, i really appreciate this DIY. just bumping it up incase anyone else needs it. really should be stickied(mods please)
also, this is the part number if anyone needs it for the oil filter. 15400-PLM-A01 they are about 7 bucks from any acura dealer
5thTo2nd (03-30-2012)
Old 03-30-2012, 01:30 PM
ddcd's Avatar
Just did my first one at 8500 miles, oil still said 30%. I went ahead and changed it since that's the longest I've ever ran oil.
I will say this car is incredibly easy, the filter is right there. On my old civic I had to do it blindly with the filter-wrench up since the filter was higher on the block.
Old 03-30-2012, 07:30 PM
MoaarLow's Avatar
Sheeesh! 8500 and still at 30%. Im blown away that im at 40% and have 3500 miles. At this rate i should get ~6000 miles out of this oil. With my previous car i was changing oil every 2000 miles. Gotta love this!! Nice DIY. An oil change is something every enthusiast should be able to do. Really simple and gets you and your car to spend some quality time
Old 03-30-2012, 08:17 PM
5thTo2nd's Avatar
Thanks for providing the part number. I'm pretty sure the Honda filter is a honeywell/fram filter.
I heard pretty good things about the HAMP (green) filters for Hondas but they're pricier so I never bothered.
yeah I completely agree.
Old 03-30-2012, 08:24 PM
PyroDave's Avatar
yea its all the NYC driving we do. plus hitting vtec hurts oil life cause it records revs i think. honestly though, it may just be cheaper to do at the dealership lmfao. filter is 7 bucks at the dealer, and then mobil1 5w-20/0w-20 is 6-10 bucks depending on where i go(pepboys and stuff) for a bottle. and i pay 25-30 bucks for the change at the dealership plus they top off my fluids like windshield wipers
Old 03-30-2012, 09:50 PM
01ITR's Avatar
*cough* civic si
Old 03-31-2012, 06:04 PM
t33h00's Avatar
Hi! Thanks for the tutorial
Can you explain more what is the Oil Catch Can for?
The Oil filter part #:: 15400-PLM-A02 is also good for use, isn't it?
Thank you
Old 03-31-2012, 07:20 PM
PyroDave's Avatar
Thank you
take a read of this, http://www.elementownersclub.com/for...t=12206&page=1
apparently a01>a02. you can get ao1 with crushable washer for $7.75 from any acura dealership. i actually got 2 for 1. the guy that did my brake change a few weeks ago got awarded top tech for the region, so i told him congrats when i stopped in today. the GM overheard, told the Service Manager to call me, i was still on the lot, he told me to come back. and he gave me a second oil filter free compliments of the GM. it wasn't an expensive loss for him, but small gesture that i truly enjoyed. i'll be emailing him ASAP
Old 03-31-2012, 09:15 PM
robm's Avatar
Nice write up on the procedure. Only one thing I would add is- anti-seize the under-cover bolts if you live in the rust belt like I do. I had one seize up and it was a bitch to get it out.
Old 04-01-2012, 09:11 AM
SEEYOU2CREW
TSXKid2010's Avatar
Just a little update:
I had to replace my undercover recently. I got genuine Acura parts, and apparently these new covers us screws instead of bolts. Maybe this happened in the MY change, IDK. can any of the 2011+ guys confirm this?
Old 04-01-2012, 01:24 PM
PyroDave's Avatar
mine got damaged, and i used gorilla tape to stick it back up how much did ya pay for a new one?
Quick Reply: DIY Oil Change
