Cold weather warm up
#41
Excessive idling can actually damage your engine components, including cylinders, spark plugs, and exhaust systems. An idling engine is not operating at its peak temperature, which means that fuel does not undergo complete combustion. This leaves fuel residue that can condense on cylinder walls, where they can contaminate the oil and damage parts of the engine. For example, fuel residues are often deposited on spark plugs. As you spend more time idling, the average temperature of the spark plug drops. This makes the plug get dirty more quickly, which increases fuel consumption by 4 to 5 %. Excessive idling also lets water condense in the vehicle’s exhaust, leading to corrosion and a reduction of the life of your exhaust system.
parasitius (01-28-2013)
#42
I Spit On You.
Idling a car for an hour wastes .75 of a gallon, it's worth it, a lot of worse things to do than warm your car up.
#43
Not sure if they have pressure sensors, but basic heat transfer principles would say your ass is much better at transferring heat than leather. Therefore, when you sit down the difference in temperature makes it FEEL cold unless the seat is hotter than you, which is not likely.
#44
I Spit On You.
I was at the Acura dealership last week because of the seat heaters, long story short they said the seat heaters on HIGH get as hot as 98 degrees without anyone sitting on them. When you sit on them it's hotter because it combines the heat.
#45
Makes perfect sense to anyone who has ever used a heated blanket! Only gets hot when insulated. Course in 'Murica, unlike Japan, we just heat our houses instead... so few know the pleasure
#47
I'm not sure why the engine warm up myth persists despite the fact that mechanics and manufacturers state that it's not necessary and inefficient at warming up the engine. Totally unnecessary in any car built within the last two decades. There are countless resources available on the web, from legit, reputable sources that state this. The only people left who still argue about it are the end users.
#48
I Spit On You.
Wtf? Gas isn't THAT expensive, it's 2x the price in Europe and more costly in other countries. People that get 25+ mpg need to stop bitching about gas. I think me going to a store a mile away is a waste of gas but at the same time im paying for my car every month, I should except to waste some gas and I dont really care about the greenhouse or emissions as the people who want priuses can help that problem. Sorry it just pissed me when people talk about wasting gas when their car gets such good MPG, when I talk about V8's and the car I want and it only gets 17mpg combined it's worth every penny.
P.s. If you want to save more gas get a bicycle, ride it to work every day, and do your chores. Shit if you get a bicicle you can save oh so much money on insurance and car payments, why stop at gas and filling up, if you cant do any of these things than put some unleaded in your tank why dont you (I know about Acura and the whole premium recommended but unleaded is okay somewhat idea).
.75 of a gallon is fine with me as long as I have my a/c working I'd be happy to be paying, way more things I waste money on than gas, shit maybe today I shouldn't have ate would of saved $10. I cant stand being in the car without the a/c being on. It's 67 degrees in my house and when it gets to 69 degrees i start itching because its too hot. Not everyone cares about emissions nor cares about gas $, its not very complicated.
#49
#50
I Spit On You.
Oh okay, if its just the exhaust system and spark plugs and things like that I'm fine with it, in a few years (I'm at 60k) I'll have to start maintaining my car like an older car because of the higher miles so when I have to get a tune up maybe at 100k or around that it'll be fine. The salt is rusting away on my minivan, have gotten the muffler replaced a few times from corrosion and not to worried about replacing the exhaust system on the tsx.
I did skim (not very fast) through the article before I posted the post before this one. Who knows I could trade this car in a few years for a TL, maybe I shouldn't be so concerned like I said other people do much worse.
#51
The way to prevent this is to get the engine to operating temps as quickly as possible - by driving the car.
At 60k miles, you're quickly approaching the end of the emissions warranty and converter failures caused by excessive cold idling are not uncommon at this mileage.
The following 2 users liked this post by ceb:
justnspace (01-29-2013),
MrLogan13 (02-02-2013)
#52
I Spit On You.
A catalytic converter can cost well over $1k to replace. A cold engine dumps exhaust into a cold cat. This leads to increased emissions and early cat failure.
#53
Haha funny, I was thinking of asking a similar question. Basically -- if the problem with idling is that there isn't a sufficient load on the engine, can't we just install giant fans under the car that can be run by the engine so that so long as it is idle it can just hover a few inches off the ground and thus be running the engine hard enough to not hurt it
#54
#55
#57
CU2 TSXClass
It's been below zero degrees in Minnesota lately so many people start cars and let run in the parking lot while they wait inside the warmth of a building. I have a garage for everyday use but today while overnight at a hotel, I had to follow the warm-up routine.
Question #1 : Will my '12 tech automatically lock the doors after a period of time thus leaving me locked out of my car with the car running and no way to open the doors?
Question #2 : Is there a way to make my car horn honk when I walk away and hit the lock button on my fob? Currently the lights only blink so I'm constantly questioning myself if I locked the car.
i believe this is what you are looking for
i hope this helps
#58
Except you'd be wrong and wasting your gas and money.
http://www.popularmechanics.com/cars/how-to/4213313
http://money.cnn.com/galleries/2007/...e_myths/3.html
http://www.thedailygreen.com/living-...warming-up-car
If you live in an area that has a really cold climate, still not entirely necessary: http://www.cartalk.com/content/do-ca...inter-mornings
Driving the car gently will warm it up faster than sitting there idling, which will cause your engine to run rich and waste gas. Using a block heater would be more efficient in cold weather, and it'd be faster too.
http://www.allpar.com/history/interv...ller-cams.html
Yeah you still need to warm up a car for a couple of minutes before just driving away and revving the engine, unless you don't like oil at the upper end of the engine. Look at the pour test in the video, even the Mobile 1 still looks like molasses in cold temps. So many times I see people just start there car and just drive it away. Those are the people that you can hear the lifters tick as they are driving there car away later in life of the car when they get higher miles on it. The "thedailygreen" sounds like a web site that cares more about saving some gas then saving wear on your engine.
#59
No one said on here that we are going to run the car for an hour, and idling the car for a few minutes is not excessive. Plus cop cars idle more then they drive them you don't see them needing engines all the time, and people driving in rush hour are idling for long periods of time too.
#60
https://www.youtube.com/watch?v=Ynag...885DB3&index=3
A moving car, with all the bits like transmission and drivetrain moving, will warm up faster and gentler than a car sitting in place with a idling engine while you're in the house drinking coffee.
#61
3-5 minutes of gentle driving to get up to temps produces less wear than 10 minutes of idling. 0w-20 is pretty thin oil, and flows fairly quickly. Idling also does nothing for transmissions, differentials, etc. Driving gently warms them up the best as well.
Having said all that, I have remote start on my TSX. I start the car just before I walk out the door on normal days, but on days when I'm driving my 1 year old daughter, and its cold out, I'll let her run for 5-10 minutes first. Her comfort takes priority over the engine wear which will not affect me in the cars lifetime with me.
#62
You shouldn't rev the engine while pulling away. As everyone mentioned, you should drive gently for the first few minutes.
#63
#64
That's right, it's on the internet so it has to be true..... Bonjour!
#66
Here are a couple more from reputable sources:
Discovery: http://dsc.discovery.com/cars/top-10/car-myths/02.html
Ft. Collins local government: http://www.fcgov.com/breatheeasy/pdf...reatheeasy.pdf
Federal Trade Commission: http://www.consumer.ftc.gov/articles...ving-money-gas
#67
I Spit On You.
FUCK THE FTC.... YO FUCK THE FTC... Whoops I mean FCC Lol <Inside Joke
MrLogan13 (02-06-2013)
#69
Umm..... it was a joke (and if you didn't recognize it, I'm not bringing you up to speed). I don't doubt that there are many accurate sources out there, plus, I already subscribe to the "start it and drive it" club.
rcs86
08-02-2016 06:52 PM
